New Topic New Reply
Author: Subject: Locost-Lotus chassis failures?
Philippe
posted on 7/1/06 at 08:04 PM Reply With Quote
Does any one have any experience or knows of any expert reports regarding the long term viability of the tube frame chassis supporting the Locost.
I have read something that amounted to a rather pessimistic account pointing to the inherent weakness of the aluminium rivet to mild steel assembly which the design calls for. But I know of little specifics.
Any views on the subject?
Philippe.
posted on 7/1/06 at 08:17 PM Reply With Quote
that would probably be down to dissimilar metal corrosion. It doesnt seem to be as big a problem as the pessimists would make out. Anyway, you can always get a new frame if it rusted over 5 years. My frame is about 4 years old and is not bad at all.
lexi
posted on 7/1/06 at 10:43 PM Reply With Quote
Common sense can go a long way toward avoiding the reaction between ally and steel. Butyl rubber or inner tube can be used as a bond breaker and if you dip the rivet in paint or varnish it helps seal it when you pop it shut. Obviously Land Rover never deployed these tactics in the past or the present.
Alex
cymtriks
posted on 7/1/06 at 11:03 PM Reply With Quote
I have heard of a different kind of failure caused by rivets fretting out.
Flex of the chassis gradually works the heads loose until the panel starts to peel off.
I've heard of rivets with extra large heads to prevent panels from peeling off.
The only way to stop this is to either track down these rivets or make the chassis a lot stiffer. That's how Caterham get away with their panels being attached by rivets.
crbrlfrost
posted on 7/1/06 at 11:06 PM Reply With Quote
Caroll Smith advocated dipping the rivets in epoxy right before popping them to fill in gaps and help prevent fretting. Most gap fillers could be used in between the sheet and the frame itself, such as a liquid nails, silicon, etc; although a bonding agent such as hysol or others would perhaps contribute added strength. Being that the panels themselves aren't terribly load bearing in the book configuration, I wouldn't worry about them structurally and once the rivets started to fret, they could be drilled and replaced with the next bigger. Gives the chassis one extra life. And if worried about internal corrosion, I know the aircraft supplied sell a anti-rust solution that they put into the structure prior to sealing it. Just a couple of thoughts. Cheers
Mix
posted on 8/1/06 at 09:00 AM Reply With Quote
For dissimilar metal corrosion to take place you need an electrolyte, In this case usually water). If you seal a rivetted joint thouroughly you will exclude the water and galvanic action will not be a problem.
Kill two birds with one stone and bond the joint with a structural adhesive and you should not have a problem with fretting.
The suggestion to dip rivets into a sealing agent prior to setting is very good advice
Mick
907
posted on 8/1/06 at 09:21 AM Reply With Quote
Spot on Mick.
Isn't DMC also between the Al rivet and the steel mandrel inside it?
Personally I've never been keen on pop rivets. They are after all only a tube, not like a solid rivet.
Paul G
Mix
posted on 8/1/06 at 09:33 AM Reply With Quote
It's a possibility, but thats one of the reasons to dip rivets before setting. If you really want to be sure seal the heads after setting.
Mick
andyd
posted on 8/1/06 at 10:36 AM Reply With Quote
Would a super glue/araldite product be a good idea do you think? Bit of a PITA to do but I'm guessing it'd seal quite well assuming good adhesion. That with a bead of silicon sealant down the seam where the panel meets the chassis rail should make it pretty moisture resistant. Also spray waxoil inside the chassis rail just to be sure.
I suppose that we'll never really know if any of this works or is necessary unless someone does a long term test with various methods and publishes the results. For me it's all down to piece of mind.
posted on 8/1/06 at 11:09 AM Reply With Quote
id just use a flexible adhesive to hold the panels on, and if you dont trust it, use a single rivet in each corner.
Philippe
posted on 8/1/06 at 11:49 AM Reply With Quote
Mick
R-Insulating rivets with epoxy or the likes is the way to go. What you are writing about the requirement for water to be present is not accurate however. Ion exchanges take place in a situation of "direct contact" between metals. This is why the Rivet industry discourages the use of aluminium rivets on steel if no insulation is provided.
Philippe.
Philippe
posted on 8/1/06 at 11:57 AM Reply With Quote
Originally posted by 907
Spot on Mick.
Paul G
R-Paul,
I am not big on blind rivets either. What you are saying though is not acurate. The rivets recommended in the case we are interested in are not exactly tubes; they are closed at one end. These rivets are pop rivets but they have been developed for the boat construction industry and designed to keep the moisture out. In my experience, because their stem is steel, they are a good deal stronger that all ordinary aluminium-aluminium rivets....still a bad way to assemble components on a sports car IMHO.
Philippe.
omega 24 v6
posted on 8/1/06 at 12:03 PM Reply With Quote
OK as I understand all previously stated comments I have a question or two.
1 Are we better to use alu or steel pop rivets?
2 What about using stainless steel fixings either rivets/mono/magnabolts or drill and tap and use machine screws.
907
posted on 8/1/06 at 12:38 PM Reply With Quote
I have a trailer made from 50 mm box with an 18g galv floor pop riveted on with 5 mm ali sealed end rivets.
When unloading sand it's dead easy to cut the top off a rivet with the shovel.
Replaced loads of them over the years.
As for the car, if I was to rivet Al to steel I think I'd go for stainless rivets.
As I have a s/s chassis with a welded in floor I only have the Al side panels to fix,
and for them I'm using M4 dome head Allen screws.
Paul G
Philippe
posted on 8/1/06 at 01:47 PM Reply With Quote
R-Stainless steel rivets would be stronger and would not rust. Note that any steel rivets requires a heavier tool than ordinary pop rivet to do the work. If you are going to use rivets, on top of using ss types I believe that proper coating of both the sheet aluminium and steel tube chassis with 2 part epoxy has to take place. This is messy but necessary.
Philippe.
omega 24 v6
posted on 8/1/06 at 01:57 PM Reply With Quote
I had wondered about seperating the ali sheet from the steel chassis with a double side sticky tape or a foam type draught excluder strip 1 inch wide.
Philippe
posted on 8/1/06 at 02:08 PM Reply With Quote
R-2
I am not sure I have done a good enough job answering your question. Here is a supplement:
If you are going to introduce a bonding agent (2 part epoxy for instance) between sheet aluminium and steel tubes...make sure that thesaid agent is heat resistant in the area of the exhaust pipes because some Epoxies are thermoplastic (they will become soft). When you use a bonding agent (common in the aircraft industry) all the strength of the assembly comes from thesaid agent; rivets are not necessary. If you are going to use rivets because you dont't want to use clamps, ordinary closed steel or aluminium rivets (with a steel stem) will do the job. Once coated with epoxy these rivets will never rust.
posted on 8/1/06 at 03:35 PM Reply With Quote
Not a thing to worry over much much about just use decent stainless closed head rivets, -- on Sevens for cosmetic the paneling tends to get renewed every few years.
I would caution anybody thinking of using normal silcone adhesives the general purpose grades are acidic.
3M Double sided adhesive tape has been reported used by some builders.
I might add that a Lotus S2 Seven chassis flexies an awful lot more than even a book Locost, Chapman on a cost/weight cutting exercise decreed that a lot of the diagonal bracing should be omitted from the already sparse chassis used on the the first series.
Mix
posted on 8/1/06 at 04:12 PM Reply With Quote
The best way to prevent corrosion in an aluminium / mild steel joint is to use 'wet assembly'.
The two components are brought together with a layer of 'jointing compound' in between and rivetted whilst still 'wet'.
Using this method in conjunction with dipping the rivets into the 'jointing compound' will minimise the possibility of galvanic action within the joint.
As BT says, some of the cheaper silicone sealants are acid, (acetic), based and are hence not ideal.
I will be using aluminium pop rivets in conjunction with structural adhesive to secure my bodywork, IMO stainless is OTT in this application.
Mick (an aircraft engineer )
posted on 8/1/06 at 06:17 PM Reply With Quote
I've had a couple of rivets give up and it's not a problem, I just put another in, the hole's already there. It's nothing structural and they only go one at a time so it's not like the panels are all going to fall off at once.
[Edited on 8/1/06 by Peteff]
omega 24 v6
posted on 8/1/06 at 06:26 PM Reply With Quote
Rivets it is then and structural adhesive.
Although with the stuff we use at work I don't fancy ever having to renew a panel as it sticks like sith to a blanket and is mega strong and grippy.
[Edited on 8/1/06 by omega 24 v6]
posted on 8/1/06 at 08:04 PM Reply With Quote
I used a PU adhesive (similar to Sikaflex) between the chassis and the ali. When I finally put the sheet in place the PU oozed out of the rivet hole - I turned the end of the rivet in that before setting it in place.
The PU got everywhere, but it cleans off with white spirit if you get to it before it hardens.
NS Dev
posted on 9/1/06 at 11:28 AM Reply With Quote
I have used ally closed end rivets with PU as well, not too much bother and as David says, the PU cleans off ok with solvent while still "wet".
Re fretting etc, I have a problem on my grasser where the solid mounted engine sets up frequencies in the chassis that repeatedly pops the heads of 4 and 5mm rivets clean off! Usually have to replace 4 or 5 each race meeting!!!! (vibration doesn't help vision at some revs either, my eyes itch!)
posted on 9/1/06 at 03:40 PM Reply With Quote
I have a vision of you chassis tubes gradually filling up with bits of "
ex-pop rivets. ;-)
New Topic New Reply
