lukefab
posted on 30/9/07 at 12:24 PM |
Puma cam belt
Hi ,
My Daughters Puma as broke its cam belt and the garage is quoting big money to repair it.
Is it worth taking the head off to check out the valves and pistons or do I buy a second hand engine ?
Its the 1700cc 16v Zetec.
I have been brought up with the old Crossflow type engine so I know b**ger all about the Zetecs.
Keith.
jollygreengiant
posted on 30/9/07 at 02:38 PM |
Cylinder head off and at least 5 valves and guides. Cheapest is second hand head OR second hand engine. you would be best off getting prices then
factor in gaskets and make you mind up.
Oh and don't forget to fit a new cambelt & tensioners.
lukefab
posted on 30/9/07 at 03:07 PM |
Thanks for the quick reply.
I am hoping for the 2nd option, "second hand head"
If all else fails, its a 2nd hand engine
I have been quoted between £600--£750.
All I have to do now is strip it down.
Thanks again !
Keith
posted on 30/9/07 at 03:57 PM |
Have you thought about a recon head? Have used Head Technique in Telford in the past.
skydivepaul
posted on 30/9/07 at 05:32 PM |
strip it down and whip the head off for a look first. a lot of the price you will have been quoted for is labour.
I had the cam belt go on my vectra sri a few years ago. i stripped it down and the pistons were o.k. and it had just bent five valves, changed these
and rebuilt it o.k.
cost me about £80.00 in total for valves and gaskets
cheers
Paul
[Edited on 30/9/07 by skydivepaul]
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
Mansfield
posted on 30/9/07 at 07:30 PM |
You need John Arnold, 01623 477854. He works from home in a properly appointed workshop that we could only dream of.
He is the proprietor of J.A.Engineering Services, 76 Somersall St, Mansfield, NG19. Don't look for him on the net as you will only find the
reminants of a guy who bought, and subseqently failed, a business trading in his name. He is 100% legit, the guy who tried to buy the business is
not.
30 years experience, you can deliver/pick up evenings or weekends and the prices are good too. Done a great job (and quick too) for me recently with
a Vauxhall Tigra head (see my recent posts for state of the head).
If you take the head to him he will tell you how much it will cost. Or even a quick chat on the phone will cost you nothing and could save you
As a guide, I wanted a head skimmed but didn't want to wait for it. He said he would do it for £25 within 2 hours of me bringing to him and I
didn't need to pre warn him.
Ended up giving him £170 because the head needed lots of work and he supplied parts.
For that £170 I got.
£36 full top end gasket set.
£12 new head bolts.
£55 head welding (the one thing he doesn't do)
That = £103.
For the remaining £67 he did the following:
Stripped the head of both manifolds, all 16 valves and lifters, skimmed the head after welding , recut the valve seats, leak tested the seats/valves,
put new the new valve stem seals in and put all the valves in. The bits he took off were neatly supplied to me in a couple of boxes. 5 day turn
around although I could have had it quicker if I needed it - 2 days of that were with the welder in Nottingham. I would not have done all that for
£67.
I have only met him twice (drop off and pick up) but I will vouch for him 100% - he did a great job for me.
U2U me if you want any more info.
Edit - he would do the whole job if you got the car to him but as said earlier most of the cash is in taking the thing apart and putting it back
together.
[Edited on 30/9/07 by Mansfield]
