Author: Subject: CHEEP HEATERS
thunderace
posted on 5/3/08 at 06:30 PM Reply With Quote
CHEEP HEATERS
http://direct.tesco.com/q/R.202-9010.aspx
tegwin
posted on 5/3/08 at 06:32 PM Reply With Quote
Good grief.....
MINE!
www.verticalhorizonsmedia.tv
posted on 5/3/08 at 07:11 PM Reply With Quote
Can you buy them instore?
tegwin
posted on 5/3/08 at 07:13 PM Reply With Quote
Dont think so...
If you spend over £25 you can have them delivered to a store for free.....
I just ordered two....no more freezing nights in the garage
r1_pete
posted on 5/3/08 at 07:14 PM Reply With Quote
Just bought a couple online £17.35 in total, only 4.odd postage, same fee to collect in store. Doesn't say whether they are on the shelves or not.
wonder what the input wattage is?
[Edited on 5/3/08 by r1_pete]
tegwin
posted on 5/3/08 at 07:21 PM Reply With Quote
It says the ouput is 1200W....given that you dont get energy from nowhere, I would hazard a guess that input would be similar...
If so, im going to end up looking like a roast duck after an hour in the garage....bring on the tin foil hat
COREdevelopments
posted on 5/3/08 at 07:28 PM Reply With Quote
would these be any good for melting powdercoat? if i bought 2 and made an enclosure for them?
r1_pete
posted on 5/3/08 at 07:32 PM Reply With Quote
Hope you're right Tegwin, it says 1200 KW, one between us would do if thats the case, can it be so?
SALAD
posted on 5/3/08 at 07:36 PM Reply With Quote
What sort of area do you think these would heat/you would feel the effects of?.........just working out how many I would need.
tegwin
posted on 5/3/08 at 07:42 PM Reply With Quote
Its a toughy...
Given that most are only 500w...and are mounted under parasoles etc.... They usualy heat quite a large area.....about 1.5 pub patio tables...
So twice as much power, twice as much heat....
If you could get it high enough I recon one would be enough to "warm" you up in the garage....
I bought two for a double garage...my logic being that, any heat is better than none!
r1_pete
posted on 5/3/08 at 07:45 PM Reply With Quote
At £6 each if you've got too many, you dont need to switch them all on, not a lot to have as spares...
SALAD
posted on 5/3/08 at 07:55 PM Reply With Quote
Indeed......3 it is then
chris_harris_
posted on 5/3/08 at 08:54 PM Reply With Quote
Just ordered three for me too. Looking forward to being warm for a change!!
Regards Chris
lotustwincam
posted on 5/3/08 at 09:09 PM Reply With Quote
Actually is says the output is 1200KW. Thats 1.2 MEGA watt. The whole street will look like roast ducks.
Don't think I could afford the electric bill!!!
tks
posted on 5/3/08 at 09:44 PM Reply With Quote
It should be 1200Watts or 1.2KW
anyway 3 of them connected all up are 3.6KWH
thats 3.6 x costs of 1 kwh per hour..
sow if one 1kwh costs 18p then 54p per hour..
5hours = 2,7pound...
(5x 54p)
Tks
p.s. also the max on a 16amp socket is (at 230Volts)
16*230 = 3680Watts
minus the 3600 the heaters take...
that leaves you 80watts
sow you will need 2 groups in the garage...
[Edited on 5/3/08 by tks]
caber
posted on 5/3/08 at 10:09 PM Reply With Quote
These things are radiant so the closer you are the smaller area the cover and the hotter you feel. they are just like lights so if they cover the area where you are working you will be warm!
Caber
caber
Caber
zilspeed
posted on 5/3/08 at 11:42 PM Reply With Quote
I thought about getting one.
Then I realised that if I work hard enough I don't get cold.
posted on 6/3/08 at 08:01 PM Reply With Quote
just to second what tks says, think about your supply before cramming a few in. Ive seen a lot of shady electrics where cables would melt before the fuse would blow.
RK
posted on 7/3/08 at 01:43 AM Reply With Quote
I want that for melting powdercoat, too. A heat gun doesn't really work I've found - too small an area at a time. Also it has a fan in it, which just blows the powder away. Now I just need to find one in Canada!
Confused but excited.
posted on 9/3/08 at 07:34 PM Reply With Quote
POO! They have been withdrawn from sale.
