b184
posted on 16/5/08 at 07:27 PM |
BMW 325 engine and box
No doubt this has been talked about time and time again, but I caint find on a search
I have an old 325 straight 6 cylinder, with a good running gear.
I was thinking of using this in a kit but not sure what chassis to use or to build one from scratch?
Do we know of the GTS bmw chassis is available or not yet?
Is anyone on here using this engine and box in anything?
Thanks for any help
D Beddows
posted on 16/5/08 at 08:17 PM |
I'm actually quite interested in this and you're not far away..... is it an old car on the drive that you're looking to turn into a
kit or have you got the car (or just the engine and running gear) specifically for a kit car?
I'm not offering to weld up a chassis for you btw but if you want to build your own I might be interested in adapting the Locost plans to fit
the BMW bits...... u2u me if you're interested
Edited to say: I'm a degree qualified automotive engineer, professional CAD monkey and I've built several 7s rather than just some bloke
who fancies a bit of a go btw
[Edited on 16/5/08 by D Beddows]
Werner Van Loock
posted on 16/5/08 at 08:36 PM |
Marlin sportster uses BMW as a donor
Marlin
Also the L&B Anaconda (fake snake) uses BMW as a donor
L&B
http://www.clubstylus.be
les g
posted on 16/5/08 at 08:39 PM |
there is guy on the haynes forum who has put that into a modified roadster chassis pictures as well
cheers les
thegasmen
posted on 17/5/08 at 08:18 AM |
bmw engine
I might be wrong
But dont luego build there seven to fit the bmw six cylinder engine.
Mick
Danozeman
posted on 17/5/08 at 08:21 AM |
The Viento is built to take almost anything.
If money was no object id love one of them marlins. mmmmmmmmmmmmmmmmmmmmmmmm
Dan
t.j.
posted on 17/5/08 at 08:38 PM |
wiesmann has one.
But there's one around here.
I will have a look.
The problem is the height and weight which are high. On the other hand you will have a "cool sound"
t.j.
posted on 17/5/08 at 08:44 PM |
it is miks15. I don't know the status, but he is using a Beemer
http://locostbuilders.co.uk/viewthread.php?tid=86707&page=&contribmessage=none
nstrug
posted on 17/5/08 at 09:30 PM |
By old I guess you mean E30 or E36? Both engines (M20 and M50) are great engines but HEAVY!!!!
Later M50s uses an alloy block so should be a more reasonable weight.
Nick
