Gezza
posted on 29/6/08 at 01:21 PM |
Power commander maps
Hi all, does anyone now if there is a specific map for a hayabusa in an mk or do you just use a bike one, if so which one is best?
thanks gerry
Jubal
posted on 29/6/08 at 06:50 PM |
I got a similarly blank response when I asked about R1 maps. I think there's very few people on here who have had their cars mapped and are
running a sufficiently generic setup to make it worthwhile sharing.
I'm just using the stock map until I can find time to test back to back.
eccsmk
posted on 29/6/08 at 10:26 PM |
i was wondering the same about a map for my zx12
im using a standard map atm but need it set for sva
going to see a chap at the weekend ill post his responce on here
posted on 30/6/08 at 12:08 PM |
You can download generic maps from the Power Commander website but the variants are based on the different systems available for motorbikes, not
kit-cars.
The whole point of fitting a Power Commander (for us at least) was to be able to tune the fuelling to suit our particular setup and ensure the engine
performs at it's optimum. The same map will not necessarily be useable for all kit cars fitted with ZX12R's. They all breath very
differently due to the way they've been built and the components used and therefore need their own individual custom map.
If you're not interested in optimum performance then just download one of the generic maps.
Phil
Gezza
posted on 1/7/08 at 05:11 AM |
Hi, i am def after best performance, it looks like a dyno job to get it sorted to its best, anyone recommended, i have a guy around the corner but bec
is not his hotspot.
gerry
posted on 1/7/08 at 11:58 AM |
Unfortunately, there are very few places that have both the facilities and capability to run a BEC car on a dyno and build you a custom map.
Since Holeshot moved to Ireland, the only three places I know of are;
PDQ - Berkshire
Powertec - Peterborough
TTS - Northampton
Phil
Gezza
posted on 2/7/08 at 05:12 AM |
Thanks for that Phil, i will look into it,
gerry
