I'm selling my eaton m45 supercharger which is bolted to a custom inlet plenum for a blacktop zetec. Also comes with charge pipe for air filter
and bypass valve for supercharger.
Produced 175bhp and 163lbft on completely standard engine, standard pulley size and no cooling. Will produce more if water meth, charge cooler or
intercooler is added or a smaller pulley, produces a big smile as is.
If you wish to install the charger with this inlet then a few modifications would be needed.
Would be willing to px or swap for a few items I'm after
-rear roll bar/cage for tiger avon.
-rear diffuser.
-carbon bits. Seats,arches,dash.
-shallow baffled sump.
-4 point black harnesses.
How much please???
Interesting, eager to learn the price.
£400 for the lot. So charger, inlet, bypass valve, small charge pipe and some brackets.
what else would be needed to fit this ?
Throttlebody &....?
Ill pm you some info
Could you pls pm me same info?
Yes no problem
£350
