Anyone going to donnington on 31st August , be the first time we have been there.
No, but if you put donnington into your satnav, you won't end up where you expect to be!
Castle Donington is the name.
Did a track day there in my 306 Rallye, and was a bit disappointed. Found the straights too long and my Rallye not fast enough for them, seemed to
just be sat there with foot to floor for ages waiting for the straight to end!
Oulton Park is a much nicer track to use imo
Did a track day there in my 306 Rallye, and was a bit disappointed. Found the straights too long and my Rallye not fast enough for them, seemed to just be sat there with foot to floor for ages waiting for the straight to end!
Was at Donington for the RS owners day last month. Cracking circuit.. check out the high speed van!
I do run a data logger, and funnily enough I topped out at 112mph. That's with 170bhp, if you've more power you may see higher speeds?
Jesus I felt really slow at 120mph on the long straights!!
If that waswith a conventional speedo then could very well be 112 or lower as they are generally 10% out, and a data logger would be gps and a true figure
Not long untill I find out.
Not been a mobile chicane at Bedford and the straight I long thrre
