i have an ally tank,where the baffle has been puddle welded in there is a leak.
any brilliant ideas how to repair it ,ive tried metal mend stuff,that only lasted a few weeks
Masking tape?
i used wurth adhesive when i had a small leak, a year later and its still sealing nicely!
I had the same problem. Fixed it with some tank sealer from Frosts. Wasn't cheap though.
yea masking take dont last too long Simon,will araldite do the job?if not ill get onto frost,s,as you can imagine getting the tank out isnt a 5 min job so i want to get it right 1st time
If you can find some give Petropatch a try , made for the job.
how about this stuff
linky
always worth a look on the frosts site as well
[Edited on 22/2/09 by bob]
drill a 4mm hole where the leak is and use sealed roof rivit!
I was going to suggest the frost stuff too. They used it in Practical Classics for a really quite manky tank and it appears it did the job
nicely....
25 quid mind
[Edited on 22/2/09 by BenB]
cheers peeps,ill get some flea bay special
ive used body filler on tanks b4 an they have always held. cheap locost solution
edited to say im an idiot an didnt read the ally tank part, so it may not work with that
[Edited on 22/2/09 by rodriguez]
I second what Rusty Nuts said - Petropatch. I repaired multiple leaks on my Montesa trials bike ali tank over 20 years ago and it is still going
strong.
M & P do it £3.49
M & P
M+P it is then,cheers peeps
