Ford axle codes
A=3.36 B=3.77 D=3.92 F=3.842 J=4.056 K=3.31 M=3.14 N=4.29 P=3.58 J=3.62 V=3.33 Z=3.59 2=4.27 3=3.62 4=3.82 5=3.26 6=3.12 8=3.56
3,14 CW47-Pin15
3,38 CW44-Pin13
3,62 CW47-Pin13
3,92 CW51-Pin13
3,77 CW49-Pin13 6.5 inch diff
3,38 fitted to 1,6 OHC ECO 5 speed
3,38 fitted to 2,0 OHC HC
3,38 fitted to 2.3 v6 ESTATE
3,14 fitted to 1,6 OHC ECO 4 speed
3,14 fitted to 2.3 v6 SALOON
3.14 fitted to 2.3 Diesel
85GG 4006 DC --- 3.97
85GG 4006 BC --- 3.62
85GG 4006 AC --- 3.38
85GG 4006 FB --- 3.36
87BG 4006 GB --- 3.14
86GG 4006 AAA --- 3.92 LSD
V87BB 4006 BAA --- 3.62 LSD
V87BG 4006 CAA --- 3.38 LSD
85GG 4006 AAA --- 3.36 LSD
Vin plate codes for Diff ratio
Ratio Code
3.14 M
3.36 A
3.38 V
3.62 U
3.64 3
3.92 D
FOZZIE/CHRIS - CAN THIS BE MADE INTO A STICKY AS IT COMES UP QUITE OFTEN AND I THINK IT WOULD BENEFIT QUITE A FEW PEOPLE...
[Edited on 15/3/08 by worX]
Info like this should really be a sticky at the top of the running gear section.
can chris or fozzie make that happen as it would save people a lot of time sifting through the site.
nice work steve
Sorry - I put it in here, as I thought it was more applicable in the tranmission section!
Could it also be moved and then become a sticky pretty please...
hells teeth that was quick
steve
I think your right, its probably either or, we should really have more info like this stuck at the top, seems a lot of other forums do it and saves
the searching.
Excellent work Steve...
I've 'stickied' it
Fozzie
Gracias
I've 'stickied' it
Fozzie
Nice one but it conflicts with what I asked last week.
Link
That means Ive left a 3.38 sat in the scrapie
Thats a bit like leaving pound notes there
Fluent in Spanish and good looking. Does this boys talents never cease
Originally posted by worX
Gracias
I've 'stickied' it
Fozzie
Steve, the VIN plate ratio codes are incorrect. The 3.62 is U
Phil
My post was mainly to get it up there as a "sticky" and I just copied the info from Fesycresy post last week, so if someone (a damn sight
more!) knowledgeable than me can clarify the details please I will amend the opening post to reflect the correct ratios and codes...
This is Previous post:
U is a 3.62:1
code list below will help
M=3.14 (7" or 7.5"
A=3.36 (7.5"
V=3.38 (7"
U=3.62 (7"
3=3.64 (7.5"
9=3.91 (7.5"
D=3.92 (7"
Link
Cheers Phil.
I've edited it to suit...
Is the 3.64 3 Ratio correct or should it be a B?
Phil
Thats all good then
Hope So!
But if not I'll keep checking back to see if anyone else has a more accurate opinion!
Low ratios in the 1.6 eh? Guess what I'm checking tomorrow - c'mon baby, be low.....
Bugger!
hi does anyone have a sierra diff ratio 3,92 CW51-Pin13 any help appreciated
07717882313 or email me on dandanracing@hotmail.com as i wont come on here often
cheers
danny
3.92 LSD = fitted to the XR4x4i 2.0 Sierra
Great info thanks.
I have been offered a Sierra diff and driveshafts, the vendor tells me the tag on the diff reads
83 BG 4006 AC
4A 377 3D14
Does anybody know the ratio.
Sierras were never sold in Oz so knowledge of codes etc is limited
here.
Wimmera
I think thats a 3.77 ratio. Even though its rarer than even a 3.14 it not a desirable ratio.
Jason
Just though I'd add that 3.36 ratio diffs can be found in 2.0 auto sierra estates and there are a few around.
Jason
Ive a diff from a 1990 2.0 DOHC
stamped on one side with 06625
on the other side it has
83BG-4025-BE
could anyone confirm what it is?
Any word on what DIFF was in the 1.8 CVH (h' Reg) that has a 5 Speed type 9.
[Edited on 28/808/09 by mad4x4]
I had a 1.8 CVH sierra from 1989. It was a 3.92 ratio.
I have been offered a diff with the folwing code: 83BG-4033-BA does the BA on the end confirm the ratio code, if so what is the ratio?
I also have the same diff code as this, anyone know the ratio yet ?
Cheers.
Hi mate, the propshaft turns just under 4 times to 1 turn of the wheel so i suspect its a 3.92 and when you have the rear jacked up and turn one wheel
the other side wheel turns the same way so i think its an LSD or been welded.
So 3.92 LSD i think, but would be nice to get it confirmed using the code stamped on it.
Just to add a bit more to this thread
I have a sierra diff hanging about in my garage which is a 3.62 I think.
it's code is = 83BG4006RG and 4A3624M07
Is the 83 the year and what does the RG signify
hi have a 3.14 diff,i was told its an lsd,do they make one from factory?
Hello,
I'm new here, but would like to update list from front page.
Diffs:
Sierra 1987-1993:
91GG 4006 ABA - AXLE ASY-RR LWHD & B 3.91 Sierra/Granada/Scorpio LSD typ 2
91GG 4006 GA - AXLE ASY-RR LWHD & B 3.91 Sierra/Granada/Scorpio typ 2
91GG 4006 AAA - AXLE ASY-RR LWHD & B 3.36 Sierra/Granada/Scorpio LSD typ 2
85GG 4006 DC - AXLE ASY-RR LWHD & B 3.92 Sierra/Granada/Scorpio typ 2
V87BG 4006 BAA/CAA/DAA - AXLE ASY-RR LWHD & B 3.62 Sierra/Granada/Scorpio LSD typ 2
V86BB 4006 AAA - AXLE ASY - RR LWHD & B RATIO 3.64 Sierra Cosworth LSD typ2
Sierra 1982-1986:
V87BG 4006 BAA - AXLE ASY-RR LWHD & B 3.62 Sierra/Granada/Scorpio LSD typ 2
Granada/Scorpio 1985-1992
85GG 4006 ACA - AXLE ASY-RR LWHD & B 3.64 Granada/Scorpio LSD typ2
85GG 4006 AAA - AXLE ASY-RR LWHD & B 3.36 Sierra/Granada/Scorpio LSD typ2
91GG 4006 ACA - AXLE ASY-RR LWHD & B 3.64 Granada/Sierra LSD (Cosworth) typ2
91GG 4006 ADA - AXLE ASY-RR LWHD & B 3.64 64 Granada/Scorpio LSD (Cosworth) typ2
Granada/Scorpio 1992-1994
86GG 4006 AAA - AXLE ASY-RR LWHD & B 3.92 Sierra/Granada/Scorpio LSD typ 2
91GG 4006 ACA - AXLE ASY-RR LWHD & B 3.64 Granada/Scorpio LSD typ 2
Scorpio 1994 – 1998
95GG 4006 AAA - AXLE ASY-RR LWHD & B 4.09 Granada/Scorpio LSD typ2
95GG 4006 ACA - AXLE ASY-RR LWHD & B 3.64 Granada/Scorpio LSD typ2
96GG 4006 CA - AXLE ASY-RR LWHD & B 4.09 Granada/Scorpio typ2 different mounting bracket (koala)
96GG 4006 BAA - AXLE ASY-RR LWHD & B 4.09 Granada/Scorpio LSD different mounting bracket (koala)
96GG 4006 DA - AXLE ASY-RR LWHD & B 4.27 Granada/Scorpio typ2 different mounting bracket (koala)
96GG 4006 BCA - AXLE ASY-RR LWHD & B 3.64 Granada/Scorpio LSD typ2 different mounting bracket (koala)
96GG 4006 BDA - AXLE ASY-RR LWHD & B 3.36 Granada/Scorpio LSD typ2 different mounting bracket (koala)
95GG 4006 AA - AXLE ASY-RR LWHD & B 4.09 Granada/Scorpio typ2
95GG 4006 JA - AXLE ASY-RR LWHD & B 3.64 Granada/Scorpio typ2
95GG 4006 LA - AXLE ASY-RR LWHD & B 4.27 Granada/Scorpio typ2
Typ 2 means that diff got bolted driveshafts.
I will update list for different ratios in few days
I have just brought a Diff from a 88 sierra with disc brakes, My friend has picked it up
Has the following codes:
88GG JB 392 4A0E04
Its a New Zealand car so this might be why I can't find any information about the ratio.. but guessing from the numbers its a 3.92:1?
So what would be a desirable diff and why ?
It depends on the wheels dimension, transmission ratios and engine RPM you are going to use.
For example for a higih reving BEC application with 13" wheels you should go for a long ratio diff like the 3.14
hi, im running a 7'' lsd from a 4c4 cosworth whats the lowest ratio available for these?
Right, here's what I've found out about the 6,5" diff over the last two weeks for future reference.
Fozzie, if you feel this should not be included, feel free to delete.
The 6,5" diff has a 6,5" diameter crownwheel (duh..) and the same mounting arrangement as a 7"diff. It exclusively uses push in shafts
that are not interchangeable with the 7"diff as they have a different number of splines at the diff end (6,5" diff has 23 splines, 7"
diff has 26 splines).
The driveshaft bearings and oil seals are not available in a rebuild kit, but have the following partnumbers:
Bearings: SKF K-LM29749
Oil seals (output shafts) 83BG-3K169 A5B (or A58, I'm not sure on that one)
For the oil seals I have used generic 40x55x10mm oil seals. Whilst the diff is not running yet, they fit the casing and driveshafts well, so I
don't expect any problems there.
I do not know the part numbers and/or dimensions of the pinion bearings and seals as I've left that well alone.
Oh, and it seems the 6,5" diff is a few (4?) kg lighter then a 7" diff.
A lot of this information came from Matt's website: CLICKY who is also a
member on here. Matt, thanks!
Regards,
Sebastiaan
Hi,
A friendly man at the local ford dealer let me use his microfiche machine and I've managed to get all the part numbers, FINIS numbers, exploded
diagrams etc for Sierra, Granada and Scorpios. I'm putting together everything I've found at
www.super7thheaven.co.uk
Hope that helps - It's a work in progress
I'm trying to found out what diff I have. The tag is completely rusted out. Can't make head or tail of the numbers. The number on the
bottom casting reads
93bg-4033-ae any ideas. As I turn it it could bd a 3.6
You can turn it and count the rotations but the only real way is to remove the rear cover.
The 4033 parts are mostly from Granada's and Scorpios.
If you remove the rear cover there should be some white or yellow painted writting on the crown wheel.
If this is missing it should also be stamped into that wheel as well.
See http://www.super7thheaven.co.uk/Sierra_Rear_Differential. Hope that helps.
Hello guys,
I've just bought a sierra from the 11 june 1990.
WF0BXXGBBBLJ30605
Fitted with a 2.0 DOHC engine
Normally, it's a XR4I.
The question is : is it a limited slip diff ?
With ratio ?
Franck
Whether it is limited slip or not, there is only one true way to tell and that is to check the small metal tag on the diff. Ford were strange when it
comes to LSD, some had it, yet other identical cars didn't. I have a 2.0DOHC 4wd and it is LSD but that doesn't mean yours will be too.
Mines a 3.92 but yours could be 3.62 or 3.92:1.
It begs the question - 'who was on LSD?'
I'm afraid I'm not into Ford numbers enough to decode the VIN number.
Sorry, but I think you've gotta get under that rear end
Unfortunately, you've got one of the diffs with the shorthand code.
But....
You have a 3.92:1 diff. Built May 8th 1990.
The JB suggests it's non LSD
Really, you need a diff with AEA or AA (anything with 2 x 'A' in it) where the JB is.
i am after a 3.92 LSD and been offered what Im told is one.... it has the following numbers:
ford 83 BG-4210-J E 3.92
89 GG-4k 343-FB
Is this the real deal? Would I be laying down a proud set of '11s' in the road, or foolishly spinning one wheel with an empty wallet??
Some knowledge on this one would be much appreciated guys....
Have you tried turning the front flange? The two shafts should turn the same way. Hold onto one of the output flanges to make sure.
Sorry, but the code suggests it's not an LSD.
Under 99.9% of cases, an LSD would have at least two A in the code e.g. 83 BG-4210-AA and not 83 BG-4210-J.
It looks like a bog stock Sierra diff to me.
my car already has a 3.92 standard diff, the last thing I want is a duplicate :-)
The owner of this is convinced his is an LSD but I didnt think the codes reflected this either. Have messaged instruction to him to test it and get
back to me.
Thanks for the reply, always re-assuring when someone says the same as I thought.
if its an aftermarket LSD (Tran-X, quaife, Gripper, ZF etc) the case tag may still show the non-lsd number. whip off back plate and take pics and post up here
That does look like a std ford oem viscous LSD to me. The fluid cartridge is on the back of the crownwheel
so it is worth buying then?
Any way of fitting the 7.5inch 2WD cossie diff (so bigger lobros 108mm) to the current driveshafts as the inner spline diameter on the 108mm lobros is larger than inner spline diameter on the 100mm lobros,e.so i quess either hybrid lobro on 108mm diameter,but smaller inner diameter,as getting a granada fiff is rare over my place..
HI
new on here but i need help can anyone tell me what diff was fitted to the 1992 sierra 2.0 gt with the doch engine i can't find any code on it
all i have is the vin number
And would this diff be better than one put into the 1.8 as that is what is fitted to my kit at the min
Thanks for any help
Hi,
New on here. Could someone help me to find which ratio corresponds to the "85GG 4006 BA" code number of the Sierra differential fitted on my
Westy ?
Besides, as I know it's a standard differential, is there a cost-effective solution to turn it in LSD ?
Cheers.
Originally posted by Wildwest
Hi,
New on here. Could someone help me to find which ratio corresponds to the "85GG 4006 BA" code number of the Sierra differential fitted on my Westy ?
Cheers.
Does this help you at all
no2
jacko
no2
jacko
Hey
Can someone confirm my ratio
My tag says;
83 BG 4006 CD
6 D28 D ? ?
Cannot read the last 2 values?
Thank you
