speedyxjs
posted on 28/11/08 at 03:47 PM |
Need help, college assignment - EFI
This is my first assignment and i normally struggle with these things.
Iv done alright so far but im struggling to describe a manifold vacuum and find out how to test a fuel injector.
Can anyone help or provide a link? I have tried wikepedia but dont quite understand the description.
posted on 28/11/08 at 04:04 PM |
you got one assignment or 3?
think of engine piston being like a pump.
If you have played with a bicycle pump or a syringe, you know that as you pull the plunger down it sucks air. If air is not able to be sucked by the
plunger then a vacuum is created.
This can be done by closing or making the hole smaller or pulling the plunger very quickly.
In an engine the plunger = piston and is moving quite quickly and the choke (disc thing in the carb or throttle body) restricts air hence you get
vacuum as the engine is trying very hard to suck air in but can't
Testing injector - these need to be connected to power supply and then the spray jet examined - it needs to be a fine fna shape - you need to google
for the photos as they are out there - I have seen them.
If you are testing them yourself, be careful as the high pressue spray can pierce your skin - injecting yourself with petrol or diesel is not
recommended.
speedyxjs
posted on 28/11/08 at 06:20 PM |
Cheers 02GF74. Thats just what i was after. Its 3 btw
rodders
posted on 28/11/08 at 06:28 PM |
I used these books a lot when I was in college and uni.
http://www.amazon.co.uk/Vehicle-Engine-Technology-Heinz-Heisler/dp/0340691867
http://www.amazon.co.uk/Advanced-Engine-Technology-Heinz-Heisler/dp/0340568224/ref=pd_sim_b_3
The first one is good as a general book that covers almost everything that you need to know that will come up in college apart from the cutting edge
stuff. The second fairly advanced but it still might be of some use to you.
As long as the assignment isn't due in soon I would advise getting a copy of the first one. Nearly everyone on my course had this book. Hope
this info helps.
Rhod
posted on 28/11/08 at 06:51 PM |
ANSU injector testing is the usual procedure.
Basically it's as described, you hook up the injectors to the test rig (which includes a regulated supply of test fuel) and fire the injectors.
The firing requirement will depend if they're high or low impedance injectors. The recent copy of PPC came with a nice description of a home
injector test kit but it only gives flow rate (cc/min) not spray pattern (the injector driver was just a simple digital on/off switch and high
impendance injectors need a high inital current followed by a lower "hold" current.
trextr7monkey
posted on 28/11/08 at 08:06 PM |
Theres a brilliant book - Modern Car Technology by Jeff Daniels very well written [not patronising!] and gives clear explanations and over views of
modern car stuff, as we are still living inthe 1970s with regard to car engineering and maintenance it was a real eye opener.
very readable - buy it or blag it!
published by Haynes so you can use your discount card at Halfrauds and get cash off
ISBN 1 85960 811 6
Mike
austin man
posted on 28/11/08 at 09:58 PM |
In the latest version of one of the car magazines practical performance Ithink,they have built a test bed which explains in laymans terms how you test
an injector flow rate etc.
