Author: Subject: wind back tool, locost?
Miks15
posted on 26/4/09 at 09:31 PM Reply With Quote
Im after a locost way (free preferably) to wind back the pistons on me VAG rear calipers.
Anyone got any solutions?
Jasongray5
posted on 26/4/09 at 09:35 PM Reply With Quote
screwdriver??
How hard can it be?
http://www.flickr.com/photos/33261515@N03/sets/72157611049241239/
adithorp
posted on 26/4/09 at 09:37 PM Reply With Quote
G clamp and a pair of grips.
http://jpsc.org.uk/forum/
rodders
g clamp
andrew.carwithen
posted on 26/4/09 at 09:41 PM Reply With Quote
On my Sierra rear calipers, I use the 'spanner' that's used for changing discs on my angle grinder (the two tangs locate within the 'v' of the pistons quite nicely)
Might work on the VAG calipers?
mistergrumpy
posted on 26/4/09 at 09:46 PM Reply With Quote
As above pliers and G clamp or peg spanner from grinder. I also have a long bolt with a wing nut on the end so that I can push and turn with a ratchet.
roadrunner
posted on 26/4/09 at 09:47 PM Reply With Quote
On my Golf i used a kwick clamp and plumbers grips thingy.
Steve Hignett
posted on 26/4/09 at 10:03 PM Reply With Quote
Kwick clamp and angle grinder spanner...
cadebytiger
posted on 26/4/09 at 10:30 PM Reply With Quote
i see you're in grantham. You don't work anywhere near notts do you? I seemed to do so many brake jobs i got the tool. welcome to borrow it
Rupert
NigeEss
posted on 26/4/09 at 10:39 PM Reply With Quote
I cut up an old socket and use that on a T bar. Works a treat.
Ninehigh
posted on 27/4/09 at 01:49 AM Reply With Quote
Do you mean wind them back as in push the piston back so you can fit new pads? I used a piece of wood and my own force last time
posted on 27/4/09 at 06:33 AM Reply With Quote
Cube wind back tools are very cheap and work well
see http://www.mptools.co.uk/products.asp?partno=52334 Rescued attachment 52334_CWT1.jpg
posted on 27/4/09 at 09:24 AM Reply With Quote
The proper wind back tools aren't that expensive.... I think I got a Sealey one for my tintop after faffing around with mole grips / water pump pliers etc etc. Cost me 12 quid IIRC... 10 minutes job done...
