Author: Subject: Sierra hub info
stuleah
posted on 15/12/10 at 08:55 AM Reply With Quote
Sierra hub info
Can anyone tell me if all the sierra hubs are the same except the cozzie ones?
marcjagman
posted on 15/12/10 at 09:09 AM Reply With Quote
4wd front are different as they have a CV joint. Otherwise all pretty much the same.
mcerd1
posted on 15/12/10 at 09:11 AM Reply With Quote
these are the ones I know of:
front hubs
  • std. sierra (with or without ABS sensor hole)
  • 2wd cossie - bigger than std. one
  • 4x4 sierra
  • 4x4 cossie
    rear hubs
  • std. sierra with drums
  • std. sierra with discs
  • 2wd cossie
  • 4x4 cossie (I think these are almost the same as std. sierra's with discs, but the caliper lugs suit bigger discs)
    granada rear hubs are 5 stud versions of the std. sierra with rear discs
    granada cossie 24v rear hubs are 5 stud versions of the cossie 4x4 ones
    (scorpio's are the same but 4 stud)
    granada / scorpio front hubs are different to any of the sierra ones
    [Edited on 15/12/2010 by mcerd1]
  • View User's Profile View All Posts By User U2U Member
    Dan.
    posted on 15/12/10 at 05:03 PM Reply With Quote
    front hubs
  • 4x4 sierra
  • 4x4 cossie
    rear hubs
  • 2wd cossie
  • What he said, however 2WD Cossie's have 2 different types of knuckles/ Uprights one has pinch bolt lower mount one has a tapered mount, much rarer (RS500 2WD Hatch) . Not sure if tere is a difference in the hubs them selves but thought it worth mentioning.
    stuleah
    posted on 15/12/10 at 10:00 PM Reply With Quote
    cool thanks for the info
    dnmalc
    posted on 20/12/10 at 12:46 PM Reply With Quote
    Note on the rear there are two sizes of drums
    DixieTheKid
    posted on 13/2/11 at 12:42 PM Reply With Quote
    Does any one know if Scorpio 24v Cosworth drive shafts and the same length as the Sierra's?
    COS IT'S Worth IT
