Author: Subject: A few hours in the garage.
AndyRead
posted on 22/4/11 at 09:44 PM Reply With Quote
As above really,
Spent some real time on the kit today.
Check out my blog if you like!
http://sdrv-stormbuilddiary.blogspot.com/
steve m
posted on 22/4/11 at 09:48 PM Reply With Quote
sometimes, is worth more than weeks of toll in the garage
steve
MakeEverything
posted on 22/4/11 at 10:03 PM Reply With Quote
Its always good to get a good run at things to make progress. I get really frustrated with just the odd half hour here and there.
ETA: ive also Made some Good Progress Today
[Edited on 22-4-11 by MakeEverything]
Kindest Regards,
Richard.
Andybarbet
posted on 22/4/11 at 10:22 PM Reply With Quote
Nice one - & sh*t me thats a tasty compressor
posted on 22/4/11 at 10:28 PM Reply With Quote
I've been in the garage all day, only just come in at 23.10
AndyRead
posted on 22/4/11 at 11:26 PM Reply With Quote
Thanks Andy B!
I love it, it just makes life so much easier!
Madinventions
posted on 22/4/11 at 11:40 PM Reply With Quote
Great looking build! I just wanted to suggest that you fit a proper mechanical switch for the brake lights that actuates from the brake pedal itself rather than the hydraulic pressure switch you've used. I've never found them to be very reliable, and it's a lot easier to do these things now while you've still got good access.
Just my opinion! I'm sure loads of people have used them without problems, but I've replaced two now on separate cars because they both failed (they only switched when there was enough pressure to lock the front wheels!)
Ed.
View my band website:
http://www.shadowlight.org.uk
posted on 23/4/11 at 12:12 AM Reply With Quote
2nd that, use a proper switch for brake lights - those take too much pressure to activate and can trap air fitted that way up.
Cracking build BTW
AndyRead
posted on 23/4/11 at 09:06 AM Reply With Quote
Ed.
Thanks for the heads up on the pressure switch, it is what was supplied with the kit.
I think i will swap for a normal switch then!
