pekwah1
posted on 18/1/12 at 01:10 PM |
Escort indicator pin thingies
Hi Guys,
Just a quick one...
Anyone know what the two sprung brass pins on this indicator unit are for?
[Edited on 18/1/12 by pekwah1]
owelly
Horn contacts for the steering wheel?
http://www.ppcmag.co.uk
pekwah1
posted on 18/1/12 at 01:12 PM |
that's what i thought it might be but they're usually on the column itself??
steve m
posted on 18/1/12 at 02:29 PM |
I thought horn conectors as well, is there two copper rings on the inside of your steering wheel?
Could they be airbag connectors?
pekwah1
posted on 18/1/12 at 02:33 PM |
hmmm... thought as much.
I think i'll just ignore them then, it's a different indicator unit from the ignition housing, mine already has the horn thingies on the
wheel and igntion housing.
Maybe i should just get the correct indicator switch unit....!
scudderfish
posted on 18/1/12 at 02:35 PM |
Is there continuity between them? Is there continuity between them and any of the pins on the rear? If you put 12v through them, where does the
smoke come out? ![](/images//smilies/smile.gif)
Michael
posted on 20/1/12 at 10:44 PM |
I think they are horn contact, as I replaced one on dads P reg escort about 10 years ago and the horn sounded putting it in.
I have the similar on my MK2 Astra switch gear on my locost, but just one at the top.
