daniel mason
posted on 2/2/13 at 09:56 PM |
live axle bec's
how do the live axle ratios effect bec performance? been reading up but cant find much about gearing. especially regarding the striker,fury and
phoenix! cheers
bigfoot4616
posted on 2/2/13 at 10:18 PM |
my 3.54 is about right for the 5vy r1 engine and was also right for the carbed blade engine. not sure about the newer blades but from when i looked
into it the busa or zx10 are no good with a live axle.
watsonpj
posted on 2/2/13 at 10:28 PM |
My furys on a 3.54 diff and is ok but it previously on 3.89 and was way to revvy on a run
TimC
posted on 2/2/13 at 10:38 PM |
As above - Carb'd Blades and R1s are about all you can use with a 3.54 ratio.
daniel mason
posted on 2/2/13 at 10:48 PM |
is it possible to fit a higher geared ratio to a live axle diff? around 3.3;1 or 3.2;1
tony.g
posted on 2/2/13 at 11:04 PM |
I run a Triumph Dolomite 1850 auto axle in my carbed blade which i think is good and is 3.27:1.
daniel mason
posted on 2/2/13 at 11:08 PM |
do you run the complete back axle or just the diff and modded halfshafts? im lookin at an lsd if possible? cheers guys
tony.g
posted on 2/2/13 at 11:10 PM |
Complete axle.
Not sure you'll get a lsd easilly.
daniel mason
posted on 2/2/13 at 11:16 PM |
no.but a fair amount of the ford axles have lsds in the kits. was wondering if a different ratio could be fiotted to the ford axle?
watsonpj
posted on 2/2/13 at 11:35 PM |
The ital axle was fitted in the caterham for a while that was available as a 3.27 and you can also get a lsd i believe.
mark chandler
posted on 2/2/13 at 11:43 PM |
You need to hunt down a Capri axle, 3ltr has a nice low ratio, 2.8i special (the later ones) had LSD although both a bit rare now and a couple of
inches wider than an escort.
Proby
posted on 3/2/13 at 10:06 AM |
I also run a 3.54 in my F27, with a carbed blade. Would be nice to have a bit more top end, as I'm maxed out at 120ish.
Visit GraphicMonster
ceebmoj
posted on 4/2/13 at 09:04 PM |
If its the Atlas axle you are talking about its also a lot heaver than the English axle. I'm not sure what ratio is in my atlas but I would like
something a bit longer. I have been thinking about dedion and a free lander diffs and sera shafts, as I would also like a wider rear tack.
Does any one know how wide the Ford Sierra rear track is?
