number-1
posted on 7/2/13 at 06:18 PM |
what airbox are you running?
Afternoon all
what airboxes are you all using and what db is your bec kicking out?
Nick DV
posted on 7/2/13 at 07:22 PM |
Modified Hayabusa airbox, tested at 97.8 db
Cheers, Nick
"The force will be with you, always!"
mark chandler
posted on 7/2/13 at 07:49 PM |
1/16" Ali air box/plenum feeding into intercooler then turbo, still whacked the meter at Goodwood to 107db which Isuspect was mostly general
engine noise.
You need to fight hard to keep a BEC low when the engine and exhaust are close together, look towards soundproofing the engine compartment to the
outside as well.
[Edited on 7/2/13 by mark chandler]
bobthebuilder
posted on 7/2/13 at 07:56 PM |
home made ally airbox with big cone filter was 102db at oulton but have changed from a k series race can to a zx12 can .
it is noticablly quieter but havent got it checked yet. if i was to guess i would say about 90 ish.
yellowcab
posted on 8/2/13 at 09:05 AM |
I'm running a standard Hayabusa airbox that I modified the cosmick way, not sure on induction levels but certainly a damn site quieter than open
bodies with a foam filter.
Feel free to check out my photo archives, I think it's in it's own folder
renetom
posted on 8/2/13 at 09:29 AM |
We used the standard R1 airbox reversed
at IVA was 97Db
carse
posted on 8/2/13 at 09:45 AM |
Running a fabricated Ali airbox with panel filter and a bit of ram air effect. It tripped the drive-by meters at Oulton at 108db - I think
they're in the vale down by Knicerbrook/bottom of Clay Hill so was screaming it in third at that point, which is why I went over.
Only solution I had on the day was to line the airbox and underside of the bonnet (which seals the chamber) with air filter material and cover it in a
protective mesh to stop it moving. It worked as I didn't get pulled again and was noticeably quieter from the outside according to people track
side.
fullpint
posted on 9/2/13 at 10:41 AM |
PiperX flat foam filter, 118db Next on my 2-buy list is a standard blade airbox (cheap) and hopefully mod it to fit under the Mk bonnet.
number-1
posted on 13/3/13 at 04:13 AM |
Cheers for the replies chaps. It seems the best way to keep noise down is keep the airbox standard?
Im doing Bedford in May and they dont give second chances for drive by noise so i need to get it right!
twybrow
posted on 13/3/13 at 08:16 AM |
Homemade carbon fibre airbox (much better acousticaly than aluminium). Not sure of exact dB, but it is pretty quiet - certainly quieter than the last
one I made for my old engine, which was 101dB.
If you can fit the original airbox, they are normally a quiet choice!
40inches
posted on 13/3/13 at 08:28 AM |
I flipped the standard airbox, keeping it to as near as standard as possible.
Although it has got a BMC air filter fitted
![](/galpreviews/Engine Bay Top.jpg) ![Description](/gallery/Engine Bay Top.jpg) Description
number-1
posted on 13/3/13 at 05:21 PM |
When the airbox arrives i may have to flip/bodge it to fit. The problem i see in my head is the 2 roll bars getting in the way of the air box....The
air box ive got fitted fits between these and is home made and incorporates a slight bit of ram air, which im told improves things a little at
speed
![](/galpreviews/) ![](/gallery/)
