shindha
posted on 26/6/14 at 10:05 AM |
Blanking rubber grommet
Hi, I need a blanking rubber grommet to block a hole about 63-64mm in 3mm thick aluminium. Does any one know where I could get one from ebay and
google have come up blank.
Thanks for looking
PS Sorry mods didnt know where to post this so if it needs to be moved please do so
Irony
posted on 26/6/14 at 11:15 AM |
http://www.skiffy.com
Free Samples!!!!!!!!!!!!!!!
shindha
posted on 26/6/14 at 11:17 AM |
Thanks for that but not the size I need.
loggyboy
posted on 26/6/14 at 12:06 PM |
Does it need to be rubber?
centrecaps
http://www.ebay.co.uk/itm/2-x-REPLACEMENT-BINOCULAR-END-CAPS-63mm-/201076895559
[Edited on 26-6-14 by loggyboy]
Mistral Motorsport
Eggy
posted on 26/6/14 at 12:11 PM |
Grommets
These guys have been really helpful in the past
(And local to me too!!)
shindha
posted on 26/6/14 at 12:54 PM |
Thanks for the replies guys,
Loggyboy it needs to be flexible as the steering column passes through it, Eggy I had a look at Grommets but they have a minimum order of £30 unless
you know better?
loggyboy
posted on 26/6/14 at 01:07 PM |
You dont need a sealed grommit then. I see..
With some sealant this is as close to 64mm as i can see
Original 2.125"' (54mm) Lucas Black Rubber Bulkhead Grommet : Part No. 51164621
Alternatively one of these could be trimmed to suit.
witches hat
Mistral Motorsport
Bigheppy
posted on 26/6/14 at 04:34 PM |
How about something like this
Boat transom grommet, witches hat for steering and remote cables
Eggy
posted on 26/6/14 at 07:26 PM |
quote: Originally posted by shindha
Eggy I had a look at Grommets but they have a minimum order of £30 unless you know better?
Give them a call........
Might have been slightly different for me as I managed to collect.......
shindha
posted on 26/6/14 at 08:36 PM |
Thanks all Eggy I did call them the nice young lady on the phone said it has to be £30 worth.
Scuzzle
posted on 26/6/14 at 08:50 PM |
What about cutting out a circular shape out of a sheet of closed cell foam and bonding it to the panel or cutting out 2x circles and bonding them to
each other with the panel edge in between. I take it it's just for draught and moisture exclusion.
