Just to be clear - this isn't sticky 3M carbon effect stuff, it's proper carbon-fibre.
I'm just wondering whether or not it will be up to the hammer that it may get from road-debris etc. It will also be close to the exhaust so the
adhesive may not stand up to much either?
Should I just bite the bullet and just get rigid carbon fiber sheet?
I'd be very interested to see how this looks, as from the description it is simply uncured carbon fibre, which isn't going to look great,
unless they have done something clever to it.
ETA: Just seen this in the Q&A
quote:the adhesive used on the sheet might not be suitable for prolonged outdoor use.
Looks quite nice in the photo though haha. They sell it at Halfords so I might go take a look, just can't imagine it'll stand up to the
heat and abuse it'll get on some rear arches.
I'm pretty sure that is the same as is on my car.
It's carbon fibre, impregnated with vinyl.
It's definately a tricky one to put on around compound curves, the weave stops it flexing in more than 1 direction.
I would say its not amazingly resillient, mine has been on about 4 years, and is well past its prime.
Once it has been stonechipped enough, it does start to delaminate fairly quickly.
Also, the backing glue is super sticky, and will peel off any stonechipped paint it is placed over.
I think i will use a proper cf pre preg type sheet when I come to replace the stoneguards.
I think that using CF as Stone Guard would be for looks and weight savings...
As stated in the previous post it is subject to the same issues you are trying to avoid in the Fiberglass below it.
A Real Stone Guard (for me) would be made of light gauge metal, either aluminium or Stainless Steel.
There is a clear film by 3M that prevents the paint from chipping, but I don´t thik it will stop star cracks.
Also, I think there´s a post here regarding the use of Mud flaps, but those may not be enogh, and also they´re not everybody´s cup of tea (or
coffee)
Last but not least, some kind of Neoprene or Buna rubber would be very effective, although may not look very good.
Regards
AA
coffee)
Regards
AA
Well my current t abs-fake carbon arche guards have been on 2 years and look as good as the day they were fitted - and I'm not particularly
careful.
I've just bought some CF sheet and will be fitting that instead - it does help that I have very very low front arches (c. 2" clearance
from the floor).
Daveb666
ABS takes impact different than Carbon, so that´s one point in favor of ABS.
But I think that your results are more due to the low level of the rear end of front arches. Thats why I commented on Mud Flaps.
One thing I will not argue against is BLING!! and lightweight.... (Well those were two...)
