<<  1    2  >>
New Topic New Reply
Author: Subject: What steel????
Simon1979
posted on 26/1/17 at 01:47 PM Reply With Quote
What steel????
Hi all im in the process of making some room and getting some funds together to start my haynes roadster. Ive been having a good look around the forum and some great info but one thing i have noticed is that all the pics i have seen on peoples chassis is that they have been made out of mild steel box section. Has anyone used s/s box section instead (just thinking about corrosion over time) are there any potential issues with using s/s box section over m/s box section.
Simon
voucht
Contributor
Posts 239
Registered 22/5/11
Member Is Offline
Photo Archive Go!
Building: Haynes roadster on the road since november 2014 bu
posted on 26/1/17 at 02:34 PM Reply With Quote
There has been a discussion about that on the Haynes forum :
http://forums.haynes.co.uk/showthread.php?t=8504&highl ight=stainless+steel+chassis
If you're afraid of corrosion with mild steel, the best thing is to have your chassis powder coated when finished. It is a bit costy, but really worth it.
https://vouchtroadster.blogspot.com/
https://cafrazx550.blogspot.com/
Bluemoon
posted on 26/1/17 at 02:35 PM Reply With Quote
Simon
Been discuses a lot, basically SS is likely to crack. If your asking the question it's not a good idea . There have been successful builds but it's unusual and I would not recommend...
If your worried about rust investigate "hot zinc spray", basically galvanization by spraying molten zinc a the steel chassis (conventional galvanization in a bath of zinc will likely distort a space frame chassis). Something I considered but this causes difficulty with some welding I wanted done latter in the build.
Dan
Bluemoon
posted on 26/1/17 at 02:37 PM Reply With Quote
Be careful with powder coating, look very nice but only good if done well, water can get traped under the coating..... Also difficult to touch up.
voucht
Contributor
Posts 239
Registered 22/5/11
Member Is Offline
Photo Archive Go!
posted on 26/1/17 at 02:51 PM Reply With Quote
Yes, of course! Professional companies, and full sand blasting of the chassis before hand. I talk from personal experience: it is one of the best investment I've done while building my Haynes. I'm very glad I went this route instead of simple metal paint.
My point was that there are durable solutions to protect a steel chassis from corrosion. Powder coating (when well done!) is one of them.
[Edited on 26/1/17 by voucht]
Simon1979
posted on 26/1/17 at 02:57 PM Reply With Quote
Thanks for the reply's guys, mild steel it is then.
posted on 26/1/17 at 03:14 PM Reply With Quote
As some of you know I'm not too happy with the powder coating on my car which has an old Luego chassis . Have just spent the last few weekends stripping the car down so that I can sort it out and have found the problem is even worse than I thought. The powder coating is pulling off in sheets and the chassis under the coating is badly rusted. Going to get it shot blasted and use something like POR15 . Don't know if this problem affects any newer than old Luego chassis's but worth checking especially you guys that took advantage of old Luego's show deals where they powder coated the chassis for free. Suspect had the chassis's been shot blasted before powder coating there wouldn't have been a problem
something I posted about 8 years ago, food for thought?
[Edited on 26/1/17 by rusty nuts]
bonzoronnie
posted on 26/1/17 at 04:47 PM Reply With Quote
Dan
I read about this Zinc coating recently ( Ralphy's westie re build thread.
Searched out some videos of the process, quite impressed TBH.
Going to look into it seriously when I drag my build out of storage.
jps
posted on 26/1/17 at 07:39 PM Reply With Quote
I've had a (mild steel) Haynes chassis sitting in a damn, half underground, 'garage'-like building after painting it with POR-15 and Blackcote for the best part of 3 years. No signs of rust. Drilled holes a few weeks ago for panels and a small amount of watery rust came out of a couple of tubes which up until then had been sealed since the chassis was welded (pre 2012!)!
Incidentally - the POR paint has been OK but, despite careful prep, has not adhered 100%. I suspect other paints would have done as good a job - without the faff involved with the POR.
I am debating whether to Waxoyl (or similar) inside the tubes before I rivet everything up - but not sure if that is overkill.
If the car is for dry weather use only I would suggest that a well painted surface with whatever metal paint you are sure is going to put up with knocks and scuffs should suffice. You may need to maintain / touch up - but it sounds as though there is no real 'fit and forget' solution here!
If you plan on the car getting wet a lot I guess there should be more work to ensure it's watertight wherever it needs it than just the outside covering: e.g. a nicely powdercoated chassis with a floor riveted on with 100 unsealed rivets will probably be at most risk from rust from the inside?!
Simon1979
posted on 26/1/17 at 11:04 PM Reply With Quote
So what would people say is a average / good price for getting the chassis powder coated?
Daf
posted on 27/1/17 at 11:52 AM Reply With Quote
I paid 300 to have mine sand blasted and powder coated. The quality is absolutely spot on. I've had suspension bits done for my other cars by the same company and they've lasted incredibly well over the years.
That 300 was for full chassis with cage.
[Edited on 27/1/17 by Daf]
Simon1979
posted on 27/1/17 at 12:23 PM Reply With Quote
Nice one cheers for that
alfas
posted on 8/2/17 at 11:39 AM Reply With Quote
powdercoating is THE modern way of protecting things....commonly used in industry, garden, construction, automotive, household machines
the most important thing is doing it the right way:
decrease, blast, passivate (zinc would be preffered), colour powder, if you want a glossy finish followed by clear powder.
the cheapish way (even TVR did it like that) is appyling the colour powder directly on the bare chassis.
more expensive way...but lasts for ever and no paint needed at all: hotdip zinc, done right with the correct preparation of the chassis in advance, it will NOT harm the chassis nor warp it.
mcerd1
posted on 8/2/17 at 12:55 PM Reply With Quote
Dax had loads of issues with powder coat quality over the years (several different companies doing the coating)
I've got a few bits done by them which are pretty shocking - were as the stuff I had done myself is 1st class but twice the price.....
If your looking for a reasonably affordable DIY solution then good chassis paint in the answer (POR15 gets a good name even if its a faf to do it right) - and paint is easy to touch up / repair if you realise you want to weld on another bracket too
but hot dip galv. needs relatively large drain holes all over the chassis, if you don't get this right you'll have some tubes full of solid zinc (heavy and the galvanizers will charge extra to the zinc that you don't want) or if you missed a tube they can blow out / pop
and the heat of the bath will warp the chassis - whether it warps it enough that you notice / care is a different matter...
lots of thin steel (probably cold formed for a lot of people (how many know the difference between EN10210 and EN10219 steel ?) with lots of welding and weird residual stresses then add 500°C molten zinc and it will warp.
not saying it can't be done - but its a PITA to get right - and the cost of gettign wrong could be a scrap chassis
[Edited on 8/2/2017 by mcerd1]
alfas
posted on 8/2/17 at 07:35 PM Reply With Quote
i had it done with a tubular seveish chassis...the holes where not that big...definately not that big to weaken the chassis...and the result was spot-on.
even 20years after built the chassis wa slike new
please also check this TVR chassis:
http://www.garagehofmann.ch/pages/tvr3000s1978.html
Simon1979
posted on 11/2/17 at 11:38 AM Reply With Quote
Just going back to the steel to be used I have the opertunity of some 25 x 25 x 3mm mild steel box section, is that the right one to use?
bonzoronnie
posted on 11/2/17 at 11:59 AM Reply With Quote
25 X 25 1.6mm ERW square tube is the correct one to use.
Plenty of builders have used the 3mm box section to good effect.
That said, the chassis will end up a lot heavier than need be.
Slimy38
posted on 11/2/17 at 12:07 PM Reply With Quote
As mentioned it's a lot heavier and a lot more hard work to cut. The corner radius isn't as sharp either, which can make T joints a bit harder to fill.
I've used 3mm for parts of the diff mounting, simply to use it up rather than any illusions of extra strength. It was also easier to weld the diff mounting plates to it, less of a difference between the 5mm plate and 3mm steel.
mcerd1
posted on 12/2/17 at 09:05 AM Reply With Quote
"25 x 25 x 3mm mild steel box section"
^^^but also that in itself doesn't tell you what kind of steel it is.....
"mild steel" is not a grade of steel in itself and covers a huge range of grades - in this country that normally means S275 for structural steel (which is what most places sell), but European S235 has become very common too - and who knows what fell off the boat from china....
the difference is the yield strength - literally 275N/mm² or 235N/mm² - they are the same weigh, same stiffness, look the same - but one will fail at a significantly lower load
but even that is not the whole story - structural steel tubes / boxes can be made 'cold formed' or 'hot finished' in the same sizes - these are totally different !
cold formed ones have bigger corner radii (which can give you practical issues when welding) and the seam is dead centre on one side, otherwise the look the same as the hot ones - but cold formed ones have no stress relief, so the buckle much more easily, they have residual stress concentration at the corners which makes it more likely to distort, crack and is just a bad idea for welding in general (at least anything that expected to carry any load)
cold formed sections are made and sold to EN10219, hot finished are to EN10210 - check the paperwork !
It doesn't apply so much to sections less than 3mm thick, but there is also the subgrade for all of the above as well - this is the toughness of the steel at low temperatures - any decent steel should be tested (charpy v-notch at +20, 0 or -20°C normally) - but cheap nasty steel will never have been tested and could be very brittle
the certificate that you SHOULD get with any steel will tell you what grade, to what standard and what tests it passed (and by how much)
if a steel supplier can't give you this then I'd have to assume they are selling doggy steel (it happens a lot)
and while were on the subject - none of the above matters unless your buying appropriate welding wire to match the grade you've got....
[Edited on 12/2/2017 by mcerd1]
Simon1979
posted on 12/2/17 at 09:16 AM Reply With Quote
Thanks for that info. I have a feeling it is the s275 grade as it is the steel that we buy through work for our fabrications. Would have to find out if we can get the 25 x 25 x 1.5mm. Our thin walled box section all comes in 3mm thickness.
snowy2
posted on 12/2/17 at 10:10 AM Reply With Quote
stainless welding is more problematic that mild steel....it can be brittle at the weld sites, it also is less flexible that mild steel (not necessarily a good thing )
your car if built properly from mild steel and rust proof it correctly it will out last you.....so whats the panic about? ;-)
as a side note my chassis is 39 years old on my phaeton......still rust free, looks like it only got painted with ordinary metal paint.....and looked after. should last another 20-30 years so 60 -70 years......thats a long time to own a kit car.
[Edited on 12/2/17 by snowy2]
sometimes you are the pigeon, most of the time the statue.
Simon1979
posted on 12/2/17 at 10:25 AM Reply With Quote
Theres no panic mate. When i started this thread i was thinking about using stainless steel as i was thinking about corrosion, but also the reasons why people dont use it.
steve m
posted on 12/2/17 at 04:19 PM Reply With Quote
My home made locost chassis will be 20 years old in June this year, its mild steel, and all as per the original book,in sizes etc
when it was finished, it was painted in red oxide, and then hammerite, and 99% of the paint is still on the chassis
Imho, no need for stainless or zinc coating, as its just adding unnecessary weight,
steve
Simon1979
posted on 15/2/17 at 08:35 PM Reply With Quote
cheers steve
WesBrooks
posted on 23/2/17 at 08:23 AM Reply With Quote
Great thread very useful for me right now!
My build is a re-body of a land rover discovery. I've built body that would usually bolt to the floor section and bulkhead of a land rover discovery. After much though I have decided that trying to save the solid rust free bits of this is likely to be less rewarding and fit for purpose than building a replacement. There are roll cage regulations that give guides on the size of the main bulkhead members (50*50*3mm) and any required chassis outriggers (100*50*3mm, using chassis spreader plates.). There is already substantial frame work in the body, and there is the chassis, so I'm thinking that 25*25mm section should be plenty to make up the floor, tunnel, and foot wells.
So am I asking for ERW EN10210 section with a strength grade of S275, or does the presence of the chassis and the body (motorsport spec tubing) reduce the strength requirements for the box section?
Would it be sensible to drop to the 2mm section for the section that is mainly being used for tunnel shape and seat/seatbelt (with suitable spreader plates) mount points, or would that make the welding tricky?
I've asked a local supplier for some prices and I will be drawing up the floor and bulkhead in FreeCAD soon. The floor section will bolt to the sills of the body (100*50*3mm section sills) and will most likely be in one piece with the bulkhead that will most likely bolt to the body somewhere around the tube that goes bellow the windscreen. For the panelling what is recommended most? Tack welding in large sheets or riveting? This is likely to get wet on a regular basis!
[Edited on 23/2/17 by WesBrooks]
http://doctrucker.wordpress.com
<<  1    2  >>
New Topic New Reply
