Hi I am considering buying an unfinished MK Indy but the scuttle is scratched and the bonnet is not with the car, does anyone know if i can still buy
the body parts for the Indy or will the parts fit from the Indy R ?
Cheers Chris
P.S. I'm a newby so please be gentle
Hi and welcome, can't you sleep thinking about it?
As far as I know the indy and indy R use the same panels and both are are still in production so you should have no problem getting them from MK
Yes, both the Indy and Indy R share the same bodywork, the scuttle and bonnet are available to buy from MK, and are both around £130 each.
Cheers guys I think i will have a trip over to MK.
Repairing a scratched scuttle should not be too hard. Neither is making your own bonnet from ally. I am very experienced in screwing up everything on my car, which is still not going after almost 4 years, and I did it, so I am sure you can too. Don't waste your money on things you are very capable of doing yourself. Just an opinion, mind!
