Pre Christmas Clear Out
ashg - 17/12/14 at 08:00 PM
Ok Im moving after christmas and im having a mega clear out
everything is collection only and must be collected before 10th january!! no exceptions!!! if you want to send a courier for smaller items thats fine.
Set of mx5 uprights (front and rear with brake callipers) no picts yet £80
large bottle of mig gas co2 argon mix (full bottle no rental) £70
large bottle of pure argon (100bar in bottle no rental) £50
playskool westfield anti roll bars. functional condition but could do with a couple of new rose joints. £100 (cost £350 new)
windscreen frame, not sure if its from a westfield or a caterham, only has perspex in it no glass £60
1l swirl pot £20
flexible 2.5 inch exhaust tube, its a little over 1m long but a bit of welding muck on one end. its 63mm id so it can slide over normal 2.5inch tube and be clamped. the way it works is you set it in position then run the engine and the heat makes it set into position £20
51mm silicone bends £10
32mm to 42mm 90deg bend unused £5
80mm un used 90deg bend £5
60mm silicone bends and ali joiners £12 (need to double check size)
roll bar for a haynes roadster £40 (left over from back when i used to do big group buys)
straight silicone hoses smallest is 32mm need to measure the bigger ones but i suspect 40mm and 70mm £15
45degree 32mm ali pipe £5
mini wiper motor mechanism in good working condition 2 speed £45.
wipers to fit the mini system very high quality stainless steel ones (need to find) £10
oil cooler £10
clio 1.4 rad with fan fits in haynes nose cone £10
[Edited on 17/12/2014 by ashg]
luke2152 - 17/12/14 at 08:17 PM
Where in Kent? I'll have the swirl pot if your close. I'm Chatham
ashg - 17/12/14 at 08:27 PM
rochester
Macbeast - 17/12/14 at 10:22 PM
Dibs on the flexible exhaust.
I'm in Maidstone fairly often and could pick up from you.
ashg - 17/12/14 at 10:47 PM
sure no problem u2u me. i go to crawley quite often if thats any closer for you?
all the silicone pipe is now sold.
Blackbird Rush - 17/12/14 at 11:12 PM
Hi Ash
Can I bag the stainless wipers please, would you be able to post them, will cover postage.
Ash T.
ashg - 17/12/14 at 11:12 PM
anti roll bars gone
mark b - 17/12/14 at 11:23 PM
I will take the oil cooler if you can post to the midlands
Mark
dhutch - 18/12/14 at 12:57 PM
Cant see the images as I am work on lunch break, but may have some of the silicon bends of you if they are black.
Daniel
Volvorsport - 18/12/14 at 01:10 PM
could do with that welding gas .... but you nowhere near me
Dick - 18/12/14 at 04:58 PM
All the hose now sold to me
nero1701 - 18/12/14 at 07:06 PM
dibs on the roll barr,
Located in bromley..
