Just fitted a pair if 7inch headlights for my 1995 striker. My chassis has headlight mounting brackets welded on. The headlights look way to high up.
Looked online at other pictures of strikers and their headlights look way lower than mine. Any ideas
min height for dipped beam headlights is 500mm (max 1m)
Not going to be for the road so no need to pass a mot. Just trying to give it a finished road going look.
This is mine if that helps? These are smaller headlights though (Dominators).
Bigger plate
I could take some measurements from the ground to the headlight mounting point if that helps?
[Edited on 25/11/19 by peter030371]
I've got 5 3/4 inch headlamps, i think that was the original spec so 7 inch will look tall.
https://www.dropbox.com/s/fa9pzmujy95womv/20170417_180310.jpg?dl=0
Dave
[Edited on 25/11/19 by obfripper]
My brackets are the same as the once in the last picture.
The lights do look a bit on the big side plus sit on top of a cone shaped mount which lifts them up even higher.
Plus can’t remove my bonnet with the lights fitted.
[Edited on 25/11/19 by cfc999]
How about this for low profile, they are Dominators with my own mounting bracket
They are 480mm off the ground, so a touch low for IVA
I've used it on country lanes at night and find them OK, if not up to modern saloon car standards
Looks like a lot of people have either cut their original brackets off or their chassis didn’t come with the brackets in the first place
Hi
I've got Dominators on mine, same as Peter's above, work just fine and back when I used to MoT it, used to go trough the test with them too.
When we first built it, had some huge things (probably circa the same as the 7 inch ones) and they actually got, visually, in the way..
I've been looking at putting LED bulbs in my Dominators. Not for more light output (but that could be a 'free' bonus) but to reduce the
power load
All the other lights in my car are LED other than dip, main and side lights.
Some of these look very good https://www.classiccarleds.co.uk/collections/12-volt-collection/12v-h4 but not yet worked out what would fit the small
Dominator shell. I am aware that strictly speaking they should fail an MOT but that is more because the MOT rules are not keeping up with technology
rather than actually being dangerous for other road users
Originally posted by peter030371
I've been looking at putting LED bulbs in my Dominators. Not for more light output (but that could be a 'free' bonus) but to reduce the power load![]()
Some of these look very good https://www.classiccarleds.co.uk/collections/12-volt-collection/12v-h4 but not yet worked out what would fit the small Dominator shell. I am aware that strictly speaking they should fail an MOT but that is more because the MOT rules are not keeping up with technology rather than actually being dangerous for other road users![]()
Originally posted by 40inches
Just noticed that they do a pair for £46 New Link
[Edited on 26-11-19 by 40inches]
But do they fit in the Dominator bowl? Its low down on my list of things to check/do as I have more pressing things to sort out to be honest its just that changing a bulb is going to be a lot quicker and easier than trying to make an under-trayI also want to check if I can fit a better sidelight bulb at the same time, do you know what type is fitted in the Dominator? I keep meaning to pop one out and look but keep forgetting as its not on my 'job list'
I am going to order a pair.
The sidelight is something I intend to check.![]()
Got to be one of these
those LEd or Xenon headlights are illegal for retrofitting...they arent e-marked, neither does your car has a self-leveling-system nor headlight
washing system. (both are mandatory for fitting such lights)
for you it might be an "upgrade" but you are not respecting that other motorists are possibly getting blinded. just a tought.
Originally posted by alfas
those LEd or Xenon headlights are illegal for retrofitting...they arent e-marked, neither does your car has a self-leveling-system nor headlight washing system. (both are mandatory for fitting such lights)
its clearly stated within the actual EU rules that the Bulb (when speaking of LED or xenon) is a part of the "headlight"....so all togehter
"headlight & bulb" have been approved and e-marked.
means you cannot fit a LED-bulb with H4-socket to a "normal" H4 headlight...as this combination was never approved, hence its illegal.
oustide UK, ALL countries and all MOT stations, would fail such a car..even the police might give you a ticket when they recognize the conversion.
in worst case the vehicle operating approval status is rendered null and void.
