CVH sump capacity
cliftyhanger - 23/3/18 at 07:42 AM
I have been searching in vain for the sump capacity of the sierra 1.8CVH sump. Can anybody help?
Clive
Myke 2463 - 23/3/18 at 08:07 AM
4.0 lt with filter.
cliftyhanger - 23/3/18 at 10:19 AM
Brilliant, thank you.
nick205 - 23/3/18 at 10:30 AM
Many car engines are between 4 and 5 litre oil capacity. If you have (or get) a Haynes manual for the donor car it'll tell you in there, as well as the recommended oil spec.
cliftyhanger - 23/3/18 at 10:55 AM
Nick, not worth getting a manual just for the sump! I have been running 4.5L as that was to the dipstick high mark. But the dipstick came with the block, not the sump. So it occurred to me I ought to check! Seems I was about right, but I will drain and refill with 4L and re-mark the dipstick.
Btw I don't trust haynes manuals at all for specs. Too many mistakes!
Dusty - 24/3/18 at 10:40 AM
If the dipstick came with the block and is the right one for that block then the min/max markings are correct for that block regardless of what sump is on there. Don't re-mark the dipstick. If 4.5L takes the oil surface to the max mark then the volume of oil that should be in there is 4.5L.
steve m - 24/3/18 at 10:55 AM
If the engine has been running fine with 4,5 l in there, that's probably the correct level
If the engine smokes a slot, then the level is to high
