welderman
posted on 6/4/15 at 12:15 PM |
Haha yes I do. And just bought 2 new Lorch mig sets on Friday. Will give one a try out on the kit.
Can't belive its happened twice now and on different sides too.
How's the cart racing going fella ?
Thank's, Joe
I don't stalk people
adithorp
posted on 6/4/15 at 12:30 PM |
Have you been jumping over hump-back bridges again?
A lot of lightweight chassis from KitCarWorkshop era had this trouble. The tubing is too thin on the diff cage. 18's gauge if I recall, but the
tolerance means it could be a lot thinner. Later ones from BGH onward have thicker tubes. Jim Giblett (twice) and Dave Hobbs have both broken theirs
but have had them remade by ProComp.
Mine was made after the problem was discovered. Having drilled through one of the tubes to weld in a bush for a towing eye it was much thicker than
18's. It also has webs from the bracket to the chassis tube to reduce the flexing, across the back of the seat and the rear mount ones go inward
to the diff cage rear tube. You can see them in this picture...
[URL=http://s189.photobucket.com/user/adrianthorp/media/fury091.jpg.html] [/U
RL]
http://jpsc.org.uk/forum/
welderman
posted on 6/4/15 at 10:27 PM |
Ah yes. I see. Will have a gook tomorrow
Thank's, Joe
adithorp
posted on 6/4/15 at 10:51 PM |
Just for reference if it happens while out/away... A jubilee clip through the bracket and around the tube will hold it in place while you find
somewhere to get it welded.
welderman
posted on 6/4/15 at 10:54 PM |
Cheers Adi will keep that one in mind.
Managed 20 miles. And did by chance went over the national speed limit a few times :0 because I'm crazy. So Tom says !
Thank's, Joe
