Author: Subject: Momentary switch solution
Jason Fletcher
posted on 18/9/11 at 09:37 PM Reply With Quote
I like the Savage momentary switches and wanted to fit them on my build but could not find an off the shelf unit that would help me do this. I was very lucky to find a very cleaver chap who when he wasn't working on a hydrogen powered car project he found the time to design and make exactly what I needed. I thought it might be of interest to the guys on here hence this thread. Also his website is not optimised as far as search engines go so you haven't got a chance of finding it other than clicking on the link below.
This is what I asked for:
Headlights switch: Press once = sides on. Press again = dipped on. Press and hold for 1 sec = off
Main beam switch: flashes with dipped off or latches when dipped is on and turns dipped off.
Indicator switches (2): press once = on. Press again off.
Hazards: This switch latches.
Fog light: Works with main beam or dipped only (IVA OK)
Heater: Press once = low speed. Press again = High speed. Press and hold = off.
Wipers: Press once = slow speed. Press again = high speed. Press and hold = off. Also self parks.
Heated screen: Press once = on. Press again = off.
Each function has two wires coming out the module, one to a switch and the other is a negative feed to drive a relay.
There is a bleep when the buttons are pressed and this can be disabled if you want.
I have done 4000 miles in the car this year and this momentary module has been absolutely perfect.
He has now put this "Multi switch module" into production so it is available. He also makes smaller modules for just indicators or lights etc.
Heres my build thread to give you an idea of whats involved. The part regarding the wiring starts from page 5. here
BTW, I have no affiliation with Paul of AMET Services other than being an immensely satisfied customer.
If you contact him tell I said hello!
AMET Services
Jason
[Edited on 18/9/11 by Jason Fletcher]
NigeEss
posted on 18/9/11 at 11:15 PM Reply With Quote
I like the way it works with any mometary switch, so it should work
with my favorite the Carling switch.
posted on 24/9/11 at 09:53 AM Reply With Quote
ah yes, the Carling switch, probably the best switch in the world.
