Author: Subject: Bell crank for gearchange - construction question
Hadders
posted on 4/2/13 at 07:00 PM Reply With Quote
I'm about to make one and I'm wondering:
1. what's the thinnest sheet successfully used for a bell crank (i have some 3mm and 10mm ali kicking around)
2. did you find there is an optimum size (e.g bigger to allow multiple mounting points to experiment with sensitivity/feel of gearchange)
What lessons did you learn? Any info to speed up the process would be most appreciated.
Many thanks
Ben
Andy B
posted on 4/2/13 at 07:30 PM Reply With Quote
Hi Ben
think I have several lying around the unit from old projects - you are more than welcome to them - doesnt really shed light on the construction but might save you time - i think one is off a Westy
regards
Hadders
posted on 4/2/13 at 07:48 PM Reply With Quote
Cheers Andy. That's very good of you. I'll send you a U2U in a second.
adithorp
posted on 4/2/13 at 08:00 PM Reply With Quote
Mine is made from 5mm steel. I found the important thing was stiffness of all the components. Any flex in the bell crank, rods or pivot and the gearchange isn't good.
http://jpsc.org.uk/forum/
Hadders
posted on 4/2/13 at 08:11 PM Reply With Quote
Thanks Adithorp.
What size is your bell crank?
adithorp
posted on 4/2/13 at 09:37 PM Reply With Quote
Best picture I could find...
