When we get around to doing the downstairs loo, the choice (if we go for a trad loo), is dig up kitchen floor (not happening), dig a trench around the
outside of the house and into garden, which will mean one hell of a hole (sewer prob 3 feet deep); will mean lifting patio and steps, probably a new
manhole etc. We already have rainwater sewer going in opposite direction down the side path, so that might even get in the way.
Been looking at Saniflow - particularly the Compact - loo/macerator all in one and would suit our needs down to a tee.
I fitted one about 4 years ago (bog with pump built in and a basin waste piped in) for a bloke round corner from me hes never said out so i assume its
fine still. I could ask him at weekend if you want as
I will proberbly see him.
The only think that puts me off macerators is if the need stripping or overhauling i just dont think i could do it
I had one fitted in the upstairs bathroom for about 18 months or so b4 we managed to work out a way of getting a 4" outlet pipe installed.
Always worked perfectly (thank goodness, cos I wouldn't have fancied cleaning it out ), tho' if you have teenage girls/women about the
place they need to be told not to put tampons down as apparently they get tangled in the macerator blades rather than getting chopped up. Other than
that, when I unistalled it, it was actually remarkably clean inside & I flushed it out & flogged it on ebay!
I installed a couple in our last house whilst they did allow us to install bathrooms where it would not have been an option otherwise, they did make a
bit of a noise which wasnt good for an en suite and each needed a bit of attention two or three times a year.
[Edited on 6/3/13 by adam1985]
If you could ask him, that'd be grand please.
Re the stripping of the macerator - I have a plumber across the road, might find me paying him for a change
Photo Archive
Building: A Single Seater that looks like a pile of Bits, a
posted on 6/3/13 at 10:13 PM
Just changed our Sanitop (loo and basin)at the weekend...it survived approx 8 years two children and their friends and at least one plastic toy
soldier!
Reason for change was the barrings (I believe) were going and it had become very very noisy and lots of vibration.
But at least it kept working rather than conking out mid pump!
New one quiet as a church mouse.
Sold loads when I used to work for the merchants and they had a very good back up system and reputation...not certain what it's like now been
out of the industry for about 6 years.
We have installed several of these on boats and have had some recurring problems. They do have a weak point in the design but it is easily fixed if
you don't mind getting your hands dirty!
The units sometimes suddenly stop working and just make a humming noise. Most plumbers solution at this point is to try to sell you a new one but the
problem is just a blown capacitor. The motor needs a high starting torque and so uses a large capacitor. This is situated inside the
diaphragm/pressure switch assembly which is right at the bottom of the unit. This switch assembly is covered by a rubber cup which is only sealed by a
jubilee clip. This seal can leak and the switch assembly slowly fills with 'water'. The unit still works at the pressure switch works on
differential pressure but eventually the water level gets to the capacitor and it blows.
An hours work and a fiver spent at Maplins, and you have saved the cost of a new unit.
Rules are for the guidance of wise men ... and the obedience of fools. (anon)
We manage several properties with them in and they regularly cause us problems.
They are noisy
To be fair it is usually operator error putting baby wipes/tampons/ moist toilet tissue/cotton wool buds etc down them.
Also they are noisy
The other thing that can happen if you are not careful about the routing of the waste pipe is that it can freeze in cold weather. If the unit is then
used then it blows up and needs repairing...
Photo Archive
Building: Fiesta Ecoboost, Porsche 924, Audi TT
posted on 7/3/13 at 11:44 AM
My parents had one fitted many years ago (15+) to create a small ensuite. The pipe run on the outside of the building is near horizontal, has three
90 degree elbows and is about 15m long. The unit has only caused a problem once - when the outside pipe froze! Not pleasant to clean up! I had to
replace the pipework (not pleasant either) as it split in several locations when it froze.
It is noisy though!
They are a solution to a problem and I would recommend if you can't get a 'proper' pipe in.
