mk3 mx5 engine + ancilliaries
Hi All,
due to breaking my wife's mk3.5 mx5 engine by running it dry (yeah, clever me) I've had to replace it with a second hand one off ebay.
This came with loads of stuff I don't need. Here's a list of things I have left over. I'm asking a bit less than the equivalents
I've found on ebay. LCB gets first dibs.
this is all off a 57 plate 1.8 petrol car
4 coil packs - £80
Fuel rail + injectors - £80
throttle body - £40
plastic inlet plenum/manifold - £20
metal inlet manifold - £20
power steering pump - £40
aircon pump - £40
alternator - £50
exhaust manifold + Cat - £50
All of the above are + delivery. I should think that will range from about £5 for small items (coil packs) up to £15 or so for bigger, heavy things
(exhaust for instance)
The engine itself is also for sale; it's been run dry and has a knocking noise (big ends)??? so needs a rebuild. Who knows what's in
there. It was running OK all the way up to when it was swapped, it just sounds like its full of marbles. In fact it did a further 300 odd miles
without too much trouble.
I'm not sure what it's worth, I'd like a quick sale so make me an offer! Collection only, near Didcot.
Other bits:
collection of hoses/pipes
small, random manifolds, thermostats and brackets.
something that looks like an oil cooler (water pipes going to oil filter bracket)
If you need any random engine related parts, drop me a line and I'll see if I have it.
