ch1ef
posted on 12/9/13 at 01:55 PM |
Luego Viento, SR20DET 400bhp
Luego Viento For Sale
Seriously fast car.
The luego Viento is a larger version of the caterham/westfield type of car and is a factory built chassis. The car has a larger engine bay and more
cabin space to fit people 6ft+ and of the larger build (Car is currently setup for me at 5ft10 but the seat can be bolted into another place to suit
you)
The car has passed its SVA check and is fully road legal. The date of first registration is 09 04 2009
TAX and MOT until 2014
Includes full build paperwork and manuals
Chassis and bodywork
Chassis is factory made buy Luego, powder coated black
Its double wishbone suspension all round with polybushes, and i had the crush tubes plated so they wont rust
The bodywork was supplied buy Luego as well
The bodywork is in a bright red colour with alloy side panels
Engine and Transmition
~400bhp sr20det engine from an s14 200sx
Garrett GT2871r turbo
750cc Nismo injectors
Z32 air flow meter
Metal head gasket
ACL bearings
Uprated engine mounts, they are nice and stiff but remove the vibrations
Tubular exhaust manifold
Uprated wastegate actuator
3" straight through exhaust
Aluminium intercooler
Apexi air filter
Apexi power fc programmable ecu with hand held remote display
AVC-R electronic boost controller
Std 200sx gearbox
ACT superlight billet steel flywheel
Exedy uprated organic clutch
Custom made dunning and fairbank propshaft
Bosch 044 motorsport fuel pump
Pace products caterham 4 core racing alloy radiator
Adjustable Fuel pressure regulator
Swirl tank
Running gear
4.1 ford sierra 7.5 Tran-x plated 2way diff
Front uprights are sierra 2wd but have been fitted with the calipers and discs from the xr4x4, the calipers have a larger diameter piston and
therefore giving you more stopping power.
Hubs have been redrilled for extra lock
Rear disc brakes from an xr4x4
Hydraulic handbrake
2.9 ratio rack fitted
Gaz adjustable coilovers
Wheels
205 50 15 Colway cut slicks (road legal)
15x8 XXR 002 wheels
4x108-4x100 PCD adapters (28mm)
Interior
2 fibreglass bucket seats
3" harnesses
Fuel switch
Battery cut off
Plumbed in fire extinguisher
VDO cockpit vision electric speedo driven from the pick up sensor inside the gearbox, with matching rev counter, water temp, fuel and oil pressure
Stack boost gauge
Bright 6 warning lights
Carbon dash
Full rollcage
Leather dished steering wheel
And lots more I cant remember at the moment!
Located between Bristol and Bath, can be delivered anywhere for a cost
I do not need to sell the car, it has cost a serious amount of time to build it. The car is ridiculously quick so no test drives without fully
comprehensive insurance that covers my car. Insurance is VERY cheap on these cars.
£9500
More pictures to come
[Edited on 12/9/13 by ch1ef]
twybrow
posted on 12/9/13 at 04:17 PM |
A price would help!
ch1ef
posted on 12/9/13 at 04:46 PM |
Oops! edited with the price
thanks!
beaver34
posted on 12/9/13 at 06:44 PM |
good price IMO
good luck with sale
DRC INDY 7
posted on 13/9/13 at 06:26 AM |
Good luck with the sale
Puddle Dodgers Club
ch1ef
posted on 13/9/13 at 12:45 PM |
Cheers guys
I would say its a very good price, once you total up the price for the engine setup, diff and rollcage your almost at the same price as I am asking
for the full car!!
Irony
posted on 13/9/13 at 01:06 PM |
I don't think your asking enough money!
I go with more and if you don't get a buyer then reduce!
ch1ef
posted on 13/9/13 at 01:26 PM |
Haha, its a fair price (well cheap if you compare it to building one to this spec!) I have put the price I am happy to sell for, Im not here to make
money etc.
As someone has just messaged me after finding the old advert from the last owner, yes the price is more than I paid but I have basically rebuilt the
car and with no disrespect to him for the great car he built I needed to make changes and redo some points to make the car better for me. The car was
more built to look nice and go well, but I wanted a more reliable car and faster car when driven hard so make a lot of changes;
I replaced the engine for a better condition item and added a metal headgasket and some ACL bearings while it was on the bench.
A new turbo and extra boost were the main addition along with new fuel maps via a PowerFC controller.
It can run actuator pressure of 9psi or is tuned for upto 1.7 bar I think (I run a max of 1.3bar on the road as never needed to go higher so far). 1.7
bar of boost will see approx 400bhp and appox 360lb/ft
A cage has been added
A 7.5" diff, shafts including a Trans-X 2way plated diff (old diff was the main let down of the orginal car)
A new cooling system was added
car was rewired for new MOT rules and simplified
Added Hydro handbrake
New cutoffs, plumbed in fire extinguisher
Better injectors
New steering wheel
More steering lock
Adjusted some bushes
Ride height adjustment
Splitter and flat bottom to engine bay
etc etc the list goes on of what I have added and how much better the car is to drive
daveb666
posted on 13/9/13 at 01:40 PM |
You shouldn't have to justify your price to anyone that knew the price you paid for it; irrelevant IMO.
Off topic, where did you get the cage please?
ch1ef
posted on 13/9/13 at 01:48 PM |
You know how people can be, they dont like to pay more than the next person but a quick scan of the two adverts would have shown some expensive extras
added, and a very different car. I am happy to justify it, as its cost me a lot more than I am asking, and is now a serious amount faster.
The Rollcage is custom made by a friend of mine who builds rollcages for race cars (well he did until a few weeks ago but might still do it if someone
wanted one, but they are not cheap). Its over engineered for regs, but I wanted safety and it to look right on the car with the larger tubing
ch1ef
posted on 20/9/13 at 04:40 PM |
I dont seem to be able to edit the first link with more pictures so here is a link to pic's on gumtree
http://www.gumtree.com/p/cars-vans-motorbikes/luego-viento-400bhp-kitcar-not-caterham-westfield-locost-robin-hood-mk-indy/1032777676
