Dopdog
posted on 21/7/14 at 02:32 PM |
Rose Joints
Dear All,
Has anyone fitted rose joints to the bottom ball joint and track rod ends. the stub axle is a cut down escort one and if you have done it do you have
any info on parts used and where you got them from.
MK9R
posted on 21/7/14 at 02:37 PM |
quote: Originally posted by Dopdog
Dear All,
I tried this on my fury but there wasnt enough rotation before the auspenaion locked out. On the mnr we now use a spherical bearing pushed into a
housing on the wishbone, it gives more free movement than a standard rose joint
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
ceebmoj
posted on 21/7/14 at 03:50 PM |
My car will use a ford Cortina upright.
I accept that the rose joints are incorrectly orientated at the in-board end.
rost
posted on 26/8/14 at 06:50 PM |
Do you use taper adapters? Where do you get those?
Charlie don't surf!
ceebmoj
posted on 26/8/14 at 08:10 PM |
I have a bored out the upright and use a spacer. I will see if I can find some pictures
Non custom
posted on 28/9/14 at 10:14 AM |
McGill motorsports is the best place for rosé joints and such like
Non custom
posted on 28/9/14 at 10:15 AM |
For anyone in future using search
http://www.mcgillmotorsport.com/
