Author: Subject: Sylva J15 at Forrestburn
theprisioner
posted on 8/8/14 at 08:00 PM Reply With Quote
http://youtu.be/MmZyk8-DNB8
Data gathered by a Sumomoto Tutor GPS and GoPro3+ and visualised under RaceRender3
The files from Tutor GPS are in .csv so you can manipulate the data in Excel/Open Office to be compatible with RaceRender.
The PC application with Tutor has too many bugs to be useful.
The big thing for me is I can now analyse my good and bad points of my driving and make progress.
The G force display is not working properly yet, this is work in progress.
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
Jenko
posted on 10/8/14 at 06:10 AM Reply With Quote
Looking good.....How's the suspension set up at the mo?. I'm finding my 200lb front springs to be very stiff.
MY BLOG - http://westfieldv8.blogspot.co.uk/
theprisioner
posted on 10/8/14 at 10:12 AM Reply With Quote
Yes I think you may be correct, I would like to try softer springs but in the list of priorities it is low at the momnt. It mostly affects me on normal roads at high speed. I have not found much problem on a track as the surface is smooth. The big issues for me so far are the wheels/tyre selection. Due to the rear tub I was restricted to 6J's and 185x15 tyres. I have now hacked the rear tub and it now has 7J wheels and 195x15 with 888 mediums fitted and what an improvement.
The next issue is brake (time to effectiveness). I am happy with the setup in principle but the front discs are too slow to warm up. I am going to try groves. If that does not work then perhaps a smaller master cylinders. I don't like that idea (right now) as I think the pedal travel may become an issue. Perhaps my change to Willwood 4 pots with vented discs was not the best choice, don't know as I never tried it without.
Also need to install a slipper in the diff.
theprisioner
posted on 10/8/14 at 11:35 AM Reply With Quote
Integrating GPS and Video files
Here is how to integrate your Time and video files:
http://gpsandkitcars.blogspot.co.uk/2014/08/integrating-time-and-video.html
