Author: Subject: J15 Bodywork
nickm
posted on 25/8/14 at 06:54 PM Reply With Quote
J15 Bodywork
Hi
Have any of you fellas put anything between the top tub and side panels such as wing piping or sealant ?
Just spent the weekend trimming the top of the dash to fit flush with the tub but after the 20th trial fit i just cheated and used chassis sponge to fill the gaps.
Nick M
Slimy38
posted on 25/8/14 at 07:25 PM Reply With Quote
I thought it was a good idea to use sponge or similar anyway to stop the two panels from rubbing as you drive? I was planning on using black draught excluder type sponge (or whatever a good waterproof automotive equivalent would be).
theprisioner
posted on 25/8/14 at 11:23 PM Reply With Quote
+1 for s/a sponge
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
Jenko
posted on 26/8/14 at 07:00 AM Reply With Quote
Nick, I must admit, I was fully intending to put some thin foam between said panels. However, totally forgot!. I think it's a good idea, and next time I have reason to remove my tub, I will be doing the same.
P.
MY BLOG - http://westfieldv8.blogspot.co.uk/
nickm
posted on 27/8/14 at 06:45 PM Reply With Quote
Thanks for the replys
I had thought of rubber wing piping with the bead on the inside to make the join between panels neat with a bit of waterproofing ? or anti rub built in.
Nick M
