scotty g
posted on 10/10/14 at 01:43 PM |
Advise on double glazing condensation, any experts.
hi all, The main panel on my double glazed front window has got condensation on the inside between the 2 sheets of glass.
Is there any way of clearing this away or do i need to replace the whole thing?
r1_pete
posted on 10/10/14 at 01:46 PM |
Replacement is the only cure I'm afraid, have had to have several replaced myself in the last few years....
cliftyhanger
posted on 10/10/14 at 01:47 PM |
You used to be able to get the panel taken away and resealed. However, that is a tad inconvenient. And I have not seen it happen for a while.
Replacement units are not too expensive. But you need accurate sizes including overall thickness of the DG unit. Which means you need to pop the beads
off usually.
It means the seal between the sheets has failed and its a new unit. I think over the years we have replaced all the units on the front of our house
which gets the sun all day....
scotty g
posted on 10/10/14 at 01:50 PM |
yeah i thought that would probably be the case but always worth asking in case someone has a locost cheat!
DW100
posted on 10/10/14 at 02:02 PM |
I'm sure if wanted to put enough effort in you could do it.
1) Put it in a container, and create a vacuum. This will evaporate the condensation.
2) Flood it with Argon.
3) seal the leak.
4) Refit
Easy!!
Slimy38
posted on 10/10/14 at 02:27 PM |
off usually.
I vaguely remember our builder saying that it's about £20 a square metre for 'average' stuff. It's not difficult to swap them
out, I replaced a glass lower door panel no problem, and it really is just finding which corner bead comes out first and then using a screwdriver and
a rag to pull them out.
cliftyhanger
posted on 10/10/14 at 02:48 PM |
I just choose the longest bead and go for the middle with a thin scraper. Lift and then work your way along. the short beads I take out last.
Short beads back in first, check packers.
A fanlight unit was under £15 recently, so no, not expensive, and pretty easy. In fact had to take a unit out a couple of weeks ago to get a sofa in a
place. Took under 10 mins each way.
owelly
posted on 10/10/14 at 04:05 PM |
I'll just mention 'security tape'......it's a right twat.
http://www.ppcmag.co.uk
whitestu
posted on 10/10/14 at 06:38 PM |
As others have said they are cheap and easy to replace. I had to swap one as some idiot managed to smash the landing window carrying a door upstairs
in our old house..
big_wasa
posted on 10/10/14 at 07:12 PM |
Doing two of mine tomorrow. Will see how it goes.
coops222
posted on 10/10/14 at 08:11 PM |
i do this for a living.
if the glass is inside a door panel then you have to replace the complete panel.
im afraid your wasting your time splitting and resealing yourself unless you replace the spacer bar around the unit as it contains a absorbent that
absorbs any moisture between the glass, if the glass is misting this means it has absorbed as much moisture as is possible and will continue to mist
up.
also if there is a creamy substance between the glass this will prove impossible to remove.
replacement or resealed professionally are the only options...
[Edited on 10/10/14 by coops222]
big_wasa
posted on 15/10/14 at 06:13 PM |
My mate came around with the new glass last Saturday, so simple and cheap to do I wish I had done it ages ago.
He did say he had never seen the security tape come of that easy.
posted on 15/10/14 at 06:53 PM |
What is security tape, if you don't mind me asking?! I've never come across it.
cliftyhanger
posted on 15/10/14 at 07:02 PM |
double sided tape that sticks the beads to the dg unit. Only used on externally glazed windows to stop scrotes popping the beads out and helping
themselves to your telly. Not always used either.
big_wasa
posted on 15/10/14 at 07:08 PM |
Yep double sided foam tape as used on kitcars
posted on 15/10/14 at 09:42 PM |
Cheers! I took out some external beads today but fortunately it was upstairs so no tape. I've always wondered why they would ever have external
beads anyway!
