Author: Subject: escort axle
loughlin1
posted on 26/10/14 at 10:36 PM Reply With Quote
escort axle
Hi all
Just a question regarding the escort mk2 axle
I am building the locost from the BUILD Your own sports car for £250
now when it comes to the axle i have lined it up BUT the drum brakes will not let me weld on the 50x50x3mm rhs CAN i turn the drum brakes 180 degrees and then fit the rhs
twybrow
posted on 27/10/14 at 12:48 AM Reply With Quote
You can remove the backplate of the drum, rotate and redrill to fix it. I haven't needed to, although my handbrake cable bracket is not ideal as a result of not doing this.
loughlin1
posted on 27/10/14 at 07:32 AM Reply With Quote
great thats what ill do many thanks
