Daf
posted on 3/11/15 at 07:44 PM |
Lathes - which one?
After about 15 years of wanting one I’m finally in a position where I can actually get myself one. However I have a big question – which one to go
for!?
Due to restricted space in my workshop it needs to be a bench mounted one and physically no longer than 1300mm. I’ll be using it for a variety of car
related jobs – probably the same sort of things that many of you on here also use them for which is one of the reasons I’m asking on here.
We have an Amadeal milling machine in work that gets used daily and is a brilliant bit of kit, the only thing that went wrong was the motor after some
ape used it to punch holes instead of drilling them! Their customer service was brilliant too following the failure, based on this I’ve been looking
at one of these:
http://www.amadeal.co.uk/acatalog/Amadeal-AMA240V-550-Lathe--10x22--Variable-speed-w-2-Axis-DRO-243643.html
From all the stuff I’ve read on various websites (including the epic lathes.co.uk!) people are saying to avoid imported new ones and go for an old
machine. The issue I have is that I don’t know enough about them to know what to look for in a used machine.
Budget – up to £1,500
Discuss!!!
Shooter63
posted on 3/11/15 at 07:54 PM |
At the sort of money in your budget I think you couldn't go wrong with a myford 7 of some sort, one with a gearbox would be great, long bed a
plus, the only problem with them is the spindle bore is a bit limiting, but a fantastic bench top machine with every accessory know to man.
Shooter
trextr7monkey
posted on 3/11/15 at 07:55 PM |
For confined space and small foot print have a look at Denford Viceroy lots of them about ex colleges, some do thread cutting very robust and
reliable -depends how often you will be using it and how big you need to go
The old Myfords which everyone bangs on about have achieved cult status and are priced accordingly.
Loads of info on Web particularly on the lathes website and there's a handy little book called the amateurs lathe which covers all of the basics
Theshed
posted on 3/11/15 at 09:00 PM |
I would not go for a Myford. Fine for model engineering but if you are doing car stuff I think they are just too small. The one in your link has some
really good features. A decent swing and a better bore and industrial size tooling (min 20mm square) is useful. Bigger and heavier is better. The dro
will make your life easier.
You should budget for tooling as well as the lathe. Carbide insert tooling is reasonable but it all adds up.
Daf
posted on 3/11/15 at 09:05 PM |
Thanks guys some interesting comments, especially: "The old Myfords which everyone bangs on about have achieved cult status and are priced
accordingly" this is something I had wondered but not actually put into words.
I presume tooling is something I can collect over time, i.e. as and when I need to make something new that requires a different tool buy it when I
need it. Kind of how I've built up my garage tools.
If I were to go and see a second hand one what sort of thing should I be looking out for and what'd be a big no?
posted on 3/11/15 at 09:15 PM |
There is a book called 'the amateur lathe', which iirc has an excellent section on buying one. There's an awful lot to know about
lathes!
Daf
posted on 3/11/15 at 09:21 PM |
lathes!
Just bought a copy off Amazon! best be good for £4 or I'll send you the bill ![](/images//smilies/tongue.gif) ![](/images//smilies/tongue.gif)
rf900rush
posted on 3/11/15 at 09:43 PM |
I went from a Warco MT300 to a Denford Viceroy, not bench mounted but not to big for a cabinet mounted unit.
Only down side for going to he Denford was losing 26mm headstock bore that the Warco had.
Just means turning lond 1" bar is now a pain.
But still very pleased with the Denford.
The don't discount the Chinese ones if cheap enough, the warco did well for my needs.
The MT300 was quite chunky for it's bench space.
I think the Clarke ML500 is very simular.
look what I found
VICEROY LATHE
NO Screw cutting bits.
[Edited on 3/11/15 by rf900rush]
Rosco86
posted on 3/11/15 at 09:59 PM |
This might be a bit big but so much better, drop a new single phase motor on it for £150 and a lick of paint
https://www.gumtree.com/p/other-miscellaneous-goods/colchester-student-6-lathe/1140683867
My Build Thread
Rosco86
posted on 3/11/15 at 10:04 PM |
I love looking for lathes and mills ![](/images//smilies/bigsmile.gif)
https://www.gumtree.com/p/lathes/colchester-student-centre-lathe-3-phase-converter/1138353499
My Build Thread
A Colchester Student is fine, if you an cope with 1250lbs of iron when moving it around! (I have one of these...). Outside of the original scope,
methinks.
You can give yourself a hernia just replacing the 3-jaw chuck for the 4-jaw. The headstock nose lock spanner alone weights 10lb and is about 3 foot
long.
[Edited on 3/11/15 by David Jenkins]
Rosco86
posted on 3/11/15 at 10:07 PM |
Yeah your right but just pointing out what's available, and so much better if you have the room
Bit smaller https://www.gumtree.com/p/other-miscellaneous-goods/boxford-centre-lathe-for-sale-/1140269630
My Build Thread
Daf
posted on 3/11/15 at 10:22 PM |
It is a bit addictive looking at machines isn't it! I'd love one of those in the links above but I really don't have space for one
plus I'm weary of handing over that much cash without the experience to know if it's any good or not!
I'ts going to have to be bench mounted otherwise the compressor has to go! Keep looking for me though, some good finds there, I hadn't
thought of gumtree.
Rosco86
posted on 3/11/15 at 10:31 PM |
Yeah no worries, I've got a mill and a lathe now but used to look every night, gumtrees really good as older people tend to use it instead of
eBay, also it is worth traveling for the right machine, good look in finding one
My Build Thread
SteveWalker
posted on 3/11/15 at 11:38 PM |
The Raglan Littlejohn Mk2 is a useful alternative to the usual Myford ML7s. The continuously variable drive speed is far better than swapping belts
between pulleys too.
rj
posted on 4/11/15 at 01:05 PM |
I agree that Myford 7's are a bit of a light duty machine, jobs just take time, they dont cope with heavy cuts, and the headstock bore is a bit
small. I have a Myford 7, 1954 vintage, still handy for some jobs, I also have a Weiler Condor - Colchester Student size, a much more heavy duty
machine.
I suggest you keep a lookout on ebay etc, and go to look at a few, so many for sale have lots of tools & extras with them.
Also check out www.lathes.co.uk, it has info on hundreds of different lathes
posted on 4/11/15 at 01:48 PM |
What makes me laugh is that the Colchester Student is regarded as a very light industrial machine, only suited for training purposes! Although I have
seen them in real workshops doing real work.
There are various small Boxford lathes for sale occasionally - meatier than the Myford, but cheaper (although model engineers in the know usually look
out for them).
This is a great site for looking up details of any lathe you might see in an on-line ad - http://lathes.co.uk/
Oddified
posted on 4/11/15 at 06:06 PM |
I have a Myford, not the biggest lathe around obviously but there's not much that you can't do on them especially if you also have a few
of the optional extras. The basic lathes aren't that expensive, but the prices soon seem to jump up if they've plenty of tooling/option
parts all nice and neat on a stand.
Ian
Daf
posted on 22/11/15 at 07:10 PM |
Well I've gone and done it! After weeks of research, hours of YouTube videos and evenings of reading (thanks for the tip on the book) I managed
to pick up a Myford super 7 with masses of bits to go with it, 4 chucks boxes of tools and even a few micrometres and Verners plus loads of other
bits!
![](http://i353.photobucket.com/albums/r396/daf318is/20151122_165424_zpsldb3vv8q.jpg)
