Author: Subject: Stylus Just Back On The Road
Fury1630
posted on 19/2/22 at 04:39 PM Reply With Quote
It's been in the garage for about six months getting re-furbed, engine bay all stripped, cleaned, painted, new engine, non-required parts removed & generally tidied up. New interior too.
Can't see how to post a pic (been a long time since I was on here) but there's some on my blog at:-
http://blatterbeast.blogspot.com/
It's now over 5 stone lighter than it was & just needs a set-up session booked for Apr 8th & it's ready for the SKCC "RogueRunners" splinter faction road trip in May.
emlyno
posted on 19/2/22 at 07:15 PM Reply With Quote
Love the blog Fury. I had a problem fitting a hi torque starter to my Gemini. The solonoid was in contact with the chassis so I unbolted the flange, redrilled the holes and rotated the flange. Problem solved. A very useful upgrade.
Emlyn Owen
wonderfulweasel
posted on 19/2/22 at 07:22 PM Reply With Quote
It looks great, well done!
Thanks for the link to your blog, I’ve not seen it before so will have a little look through.
Fury1630
posted on 19/2/22 at 08:30 PM Reply With Quote
Thanks, the blog's been going over 10 years, there's over 500 posts, mostly about the Fury, then there's a bit of a gap after it met it's dad demise, then restarted with refurbishing the Quantum & then the Stylus.
The starter I was sent had a ring of holes for adjustment, but either the big power stud was right against the engine, or the chassis was in the way, or the solenoid bit was hanging below the sump. None of those options appealed
scudderfish
posted on 19/2/22 at 10:16 PM Reply With Quote
Your blog is in ,my RSS feed I didn't realise you also frequented here.
