Not sure if this will help anyone else, but it certainly annoyed me! So thought i would share...
Last weekend i managed to get the busa engine ready to be fitted into the chassis, so i bolted on the engine cradle to the motor and lifted it in.
To my amazement, none of the chassis bolt holes lined up, at first i thought we had done something wrong, but after 3hours of 'adjustment'
we found that the engine cradle doesn't line up wit the chassis at all!
And to top it off, my £1500 dry sump also hits the bottom chassis rail. arrgghh
So to avoid that we have to slightly angle the motor, and now the cradle lines up even worse.
So i'm making my own one now.
why is nothing ever simple and straightforward!?!
Rant over.
I've sickened myself with mine, haven't been in the garage for 3 weeks.
Holidays shortly so it will be another couple of weeks.
Some of that welding is only diy standard aswell
Can I ask politely who fabricated the engine cradle for you ?
Doesn't look like there's enough penetration on the welds there. They look like stuck-on cuckoo poo type welds.
I think you should send it back and get a replacement or refund, send them the pictures too and mention it's on the forum
[Edited on 28/6/12 by Mr Whippy]
How frustrating. Sadly, it seems there is a real problem with quality of components from some suppliers in this industry. I would send the cradle
right back to whoever made it for a full refund.
I had similar issues with the engine mounts (and many of the other components) BGH Geartech supplied me - they were badly made and ill fitting. I had
to chop them up and remake most of them. Dealing with an incompetent kit supplier can cause huge amounts of stress and frustration - I hope its just a
one off and the rest of the parts in your kit are better made.
Jek
I had the same problem fitting my engine, took me all day most holes didnt line up.
I would still mention it too them cos if you don't this may not be the last post with one of these not fitting
my MK stuff years ago all was quite well made, I'm suprised they have done that bad
I'm with big wasa on this one. JEEEEEEEZUz them welds look poor to say the least. Question is, what is out?? the chassis or the cradle ( which should fit your chassis.
Makes me very glad that I brought my car second hand pre built. It costs less and lets someone else loose their mind over building it.
If you want to build a car. Buy second hand then dismantle, recondition and rebuild it to your spec!
I hope the rest of your build goes well. MK seem to be getting kicked about recently. I hope their quality and customer service picks up soon, they
are a big player in this industry and need to set an example.
This was supplied by MK with the chassis.
i could chase up for a replacement, but i probably still won't be happy with it - so i'll make my own.
its just the time thats wasted that really bugs me, i only get one day a weekend to do this stuff. Ah well its a lesson learned i guess (first ever kit car) , check the engine fits before anything else!
cheers.
I had exactly the same problem with my hayabusa cradle too (along with many other faults). I had to bend it into position with a block of wood and a lump hammer to get it close enough to fit! It was 90 quid for that bit of wrongly made metal too. When i raised this with MK i was told by Phil it wasn't possible to be wrong as they were made in a jig and basically get stuffed. My indy R has caused a huge ammount of stress and pretty much all of it has come from MK's poor workmanship and lies.
Mr C, I couldn't agree with you more.
Cowboy kit companies need to face up to their responsibility to provide goods which are fit for purpose and delivered on time. Instead, some seem to
be in the habit of taking orders under lead times they have no hope of delivering upon and bodging parts together with a sloppy 'that'll
do' attitude before firing them out the door without even checking if they fit. This was certainly my own experience of dealing with BGH.
Buying a kit from the company I did has been, I think, one of the most regrettable decisions I've ever made. Will it be worth it in the end? No
way! I'm sure I'll still be pleased when its done, but there's not a chance it's been worth all the frustration with poor fitting
parts which were delivered months (sometimes years) late and the hassle of having to phone up week after week to be given the same excuses again and
again.
Thankfully, there are kit suppliers out there who offer good quality, well engineered goods, and great customer service. I only wish I'd bought
from one of them, and would encourage anyone thinking of starting a build to consider the supplier's reputation as the primary consideration when
choosing a kit!
It is such a same to read this thread but it does seem that MK either do a wonderful job for some people or a complete bag of s**t for others. I do
feel you as there is nothing worse than spending hard earned cash to find it was a waste of money. you then have to fix it yourself. send it back and
get your money back off them.
cheers.
If that was made in a jig, then the jig is wrong, they'd have been better off making it in situ.
I'd sent it back, say that others have had similar probs. Substandard goods ain't clever.
Simon
What my mum would call a friday afternoon item..... cause everyone's buggered off home!
Even to my untrained eye the welding looks bad. They must have let a work experience lad build that one lol Send it back!
That welding is shocking
Fully agree with the welding comments - my welds looked like that when I was learning (they're not much better now!!) but that is VERY
substandard. If you don't demand a refund, you want your bumps feeling! Start by sending MK those photos showing the welds and ask them why you
shouldn't take it to the local trading standards office.
Even if it had lined up, and you had fitted it, I reckon the welds would fail in use. I don't think the IVA inspector would pass it, either.
i hope the cradle is out,becausus handling er if its chassis which is not square your gonna have some serious handling issues
Interesting thread in as much as yes the supplier ( who is a regular on here ) should be refunding you, but as yet he hasn't replied on here at
all. ??
I doubt the chassis is out, as, looking at the pictures, the casing on the box/engine is way out from the mounting boss.
You need to get a refund OR a properly fitting/ welded cradle.
The point of this guys thread is the stress. Complaining and trying to practically beg for a refund IS stressful.
If you can avoid it and have the skills then doing it himself might feel like a better option to him.
I see what you're getting at Dangle but on the flip side, Firstly the nagging stress that you paid for something that is wrong would slowly drive me mad and secondly if MK aren't notified and sort this out countless others are also going to experience this stress and might not have the skills to rectifiy it.
Trust me MK have been notified and seem to have done absolutly nothing about it.
Woah calm down! I posted this up just to share my problems with like minded people for a bit of support - not boycott a manufacturer!
I have not spoken with MK, and i'm sure if i had done I may have been able to source a replacement engine cradle. Its my choice to fabricate my
own, purely down to being a fussy git and wanting to get the car built asap.
Obviously i'm not the first person to have issue's with the MK builds, many here have had varying problems. As a 'newbie' i
don't know if its just part of building a kit car, but hopefully these forums will help others watch out for potential problems before they get
to far with their own builds.
cheers
C.
I admire your extremely chilled attitude, I wish I possessed a similar mins set. I still feel though that MK should be made aware of your problem as others further doewn the line may not have your skills and abilities to fabricate items that should of been correct in the first place.
Woah calm down!I posted this up just to share my problems with like minded people for a bit of support - not boycott a manufacturer!
I have not spoken with MK, and i'm sure if i had done I may have been able to source a replacement engine cradle. Its my choice to fabricate my own, purely down to being a fussy git and wanting to get the car built asap.
Obviously i'm not the first person to have issue's with the MK builds, many here have had varying problems. As a 'newbie' i don't know if its just part of building a kit car, but hopefully these forums will help others watch out for potential problems before they get to far with their own builds.
cheers
C.
I hit the exact same problem with my sump. I eventually used the same cradle, just moved it about 1 inch to the right. I also raised it about 1/4 inch
so I could run a flat bottom.
Keep in this affects several things. My exhaust is now very close to the body and the shift cable never lined up right again.
For this specific problem you really cannot blame MK. Come on... You buy a kit to use standard engine parts then swap them out for aftermarket, with a
drain in a completely different location and it does not fit and you want to blame the manufacturer? really... Wow
Originally posted by fimi7
I hit the exact same problem with my sump. I eventually used the same cradle, just moved it about 1 inch to the right. I also raised it about 1/4 inch so I could run a flat bottom.
For this specific problem you really cannot blame MK. Come on... You buy a kit to use standard engine parts then swap them out for aftermarket, with a drain in a completely different location and it does not fit and you want to blame the manufacturer? really... Wow
The exhaust being close to the body seems common also, which suggests a design flaw or as previously posted by someone on this thread, the Jigs are
wrong.
But, i suppose that'll t'do for some.
So not only should a hammer and crowbar be included in a kit, but a hacksaw / dremel too?
Re; 'Stress'.
I have found over the years that it is better not to get wound-up, but to look calmly upon things that go wrong as a challenge.
As far as 'Stress' goes, it is much better to give than to receive, so this is what I now do.
I let the other side have all the stress.
As far as I know MK now sell the SBD dry sump despite being well aware that a busa engine with one attached clashes with their placement of chassis
rail - mine was exactly the same.
In the end I modified the rail itself rather than move the engine. Your weld quality on your engine cradle is far worse than my own MK one - looks
crap really, I'd get it re-done, probably not by MK but by a proper welder unless you're local..
It suprised me as my roll cage welds by MK were very good.
[Edited on 13/7/12 by Custardpants]
I can sympathise totally with the stress building/working on your own car
I,ve just completed a drum to disk conversion, what i thought was going to be straight forward. Turned out to be a bugger of a job. Although in the
end i managed it, the stress of trying to sort it out , for me out weighed to satisfaction of doing it myself.
I have just had the car picked up by MK whos fitting a new body and a roll cage, then the cars going to York to have a new engine fitted where i will
pick it hopfully all done. I was going to do it myself but just dont want the hassel.
Although I can understand how you can have one of those days when nothing goes right, and every small thing seems to be an uphill struggle, I found
going in the garage for months on end building the car to be actually very enjoyable and theraputic.
I know for a fact that it did help that I always had plenty of time on my hands - courtesy of the great shft system I work (4 on 6 off).
STRESS! STRESS! dont tell me about stress!
Try building a car with no manuel and upto 15 twelve to seventeen year olds in tow.
oh the blood!
isn't even my car at the end
[img]
[/img]
[img]
[/img]
Actually its not too bad provided you stay completely chilled and keep things in perspective
No body died (so far) and everything done once can be re done and its (supposed to be) an interesting and enjoyable project.
Anybody local is welcome to pop in and see what we are doing during our Saturday morning car building club.
If anyone has any donations by way of unwanted materials, engines (lawn mower, scooter etc), tools or even money they would be gratefully received
and will go towards teaching our youngsters the benefits of DIY mechanics or completing our build
Cheers all
Steve P
Team SCAR
[Edited on 15/7/12 by SCAR]
