CBR1000RR Idle Speed
enginearin - 19/11/12 at 04:02 PM
Hello all,
Just got the car going again after swapping in a replacement '05 engine (broke the previous gearbox) and the car now idles at 2450rpm regardless of engine temperature.
Anybody got any idea of what i should be checking? I thought that it may be an airlock in the automatic fast idle adjuster thing (has coolant piped though it)... any thoughts?
I used the throttle bodies and sensors off my previous engine, so the TPS should be fine. Could it be other sensors? Would a faulty water temp sensor cause these symptoms? I measure water temp in the top hose, so i have no read out for the original engine coolant temp sensor.
Any ideas gratefully accepted
Tim
Davey D - 19/11/12 at 05:24 PM
doesnt it have a knob to manually adjust the idle? my 06 Yamaha R1 does. a flexi pipe with a knob on the end... goes to a grub screw that opens the throttle boddies
Bare - 19/11/12 at 05:47 PM
Hmmm.. Just went through my '08 CBR600RR oem service manual seeking advise on this.
Seems that the IAC valve is the ONLY idle control . No idle screws to dick with... beyond basic throttle cable adjustment
Certainly a possible sensor issue. Or even a loose plug connection or air leak from a misaligned hose?.
The ECU has a Diagnostic on mine.. allegedly a very good one.
I'm thinking a few mins with a Honda Code reader Gizmo (likely Dealer only though) would reveal all ?
Gotta love moderne electronics.. having said that; at least it's a Honda system which has time proven incredibly reliable.. unlike those horrid Bosch based bungles :-)
Andy B - 19/11/12 at 08:10 PM
The stock temp sender can cause this as it supplies the info to the ecu that affects fuelling, also check all the vac hoses that hook up to the map sensor. If you still have issues call me on 07906561838 as my landline is still down due to BT being an inept bunch of clowns but that's another story!
Regards
enginearin - 19/11/12 at 08:33 PM
Thanks Both... i have an adjuster knob on my '05 blade engine, but it's not that.
Regards
Thanks Andy... i'll check all the vacuum lines and check wiring to the temp sensor. If still stuggling will swap the temp sender with the one from the old engine.
Hope you're back online soon!
Further to our last telephone conversation... I just sold my house this weekend, so i might make a couple of races in RGB next year after all
enginearin - 4/12/12 at 12:58 PM
For completeness... it was coolant sensor.
Thanks for all the help
Tim
