Right after it sitting all wrapped up for 3 years of not having any time i give up so all parts are for sale.
let the list begin;
All parts are brand new unless stated and either in box or mounted but nothing has ever been run.
Rotrex C30-94 kit with 110mm pulley: £1100
Custom GRS rad/intercooler inc fan (mounted) (same as flakmonkeys old one): £600
Escort 2.1 quick rack (covered 500 miles): SOLD
Escort steering column with quick release steering hub: SOLD
Seimens Deka injectors 630cc: £175
Cosworth roller barrel throttle bodies: £650 (prov sold)
Pulsar plenum and backplate to suit tb's: £60
Wilwood midilite Front vented brakes, all mounts, discs and pads and braided lines (covered 500miles): £350
OBP super light weight pedalbox, remote pots, complete bias and dash adjuster, hyd clutch, 3 MC's: £300
Customer ali header tank with low level swicth etc: £45
Type 9 quaife straight cut gearbox, just been serviced, new seals and bearings + short shifter 2.04 1st gear: £650
Type 9 duratec bell housing hyd clutch: £125
Slave cylinder to suit above and mount: £50
Tran x lsd diff for Atlas axle Grp4 gears (never out of box): £700
Tran x 2 peice grp 4 shafts 740mm(never fit): £300
Complete atlas axle 52inch, 3.75 open diff. Disc braked with cossy calipers, fit under 13's (mounts to suit coilovers/4 link etc): £350
Ali fuel tank, baffled, integral swirl pot, outlet, return and vent. suit 7 style kit: £125
Sytec 255lph external pump and seperate filter and mounting brackets: £75
Complete wiring loom to suit 7 style kit, full lighting etc including fuse boxes etc (installed but never used): SOLD
Omp D shape alcantara steering wheel (700 miles): £60
JK composites seats, black with black 5 pad set, carbon tops (500 miles, not one mark on them): £200 (prov sold)
Luke Gmax 4 point in black harnesses, Pair (500miles): £90 (prov sold)
Carbon fibre aeroscreen: £80
Carbon fibre cycle wings: £100
Carbon fibre rear arch stone gaurds: £50 (prov sold)
Custom carbon fibre silencer heat shield: £100
2 sets (8) 205/60/13 Yoko advan A048 tyres, 4mm on all: £200 a set (one set sold)
Spa plumb in fire system with two nozzels: SOLD
Forge competition dump valve: £30
4inch lights to suit 7 kit: £40 (prov sold)
Forged duratec 2.0
wossner 88.5mm 8.5:1
pec rods
acl race bearings
ARP main and head studs
ARP con road bolts
Key'd crank and pulley
Lightweight flywheel
Helix paddle clutch kit
All lightened and balanced, decked block. bored, honed and line honed. (all done and assembled by Scholar race engines)
Ported and polished head
Uprated piper valve springs and retainers
all new seals and relapped valves
All valves gaps set with new buckets
Cometic MLS headgasket
New chain and tensioners (cosworth items)
Denso spark plugs
Cleaned up front cover (de mounted)
Titan dry sump 3 stage pump
Ali water outlet
£3000 (prov sold)
Custom ali fuel rail to suit duratec: £75 (prov sold)
Racline tensioner: £70 (prov sold)
Lightweight denso alternator inc pulley: £50 (prov sold)
Magnacor ht leads duratec in blue: £50 (prov sold)
Digidash 2, inc loom and all sensors: £275
Also kit car breaking so ask for any bits too. Is complete car at present.
Think i have covered all but sure i will add bits i have forgotten (its been a while).
Again all parts a brand new and either bolted on or still in box unless stated.
Pics avliable on request and hope price are about right but open to offers, let me know if i offend...lol.
text or call, 07706 715297
[Edited on 13/3/13 by goaty]
[Edited on 14/3/13 by goaty]
Bargains Galore... So tempted on pretty much everything!
Dibs on alternator
[Edited on 13/3/13 by eddie99]
i got no idea what its all worth, loosing fortunes here though....lol
U2U sent for seats,harness and h/lights
u2u'd re rack
2nd dibs for seats, harnesses and lights.
i am looking for a chassis and bodywork also front wishbones.
what ya got.
Hi
Is the dry sump tank up for grabs please.
I need to replace mine. If it is, please could I have dims and a price please.
Many thanks
Gavin
Dibs on this please, have you a closer picture?
what ya got.
that thing would be a weapon if ever completed.
i need some seats but cant be arsed on 3rd Dibs!!
good luck with the sale.
I'll have the Carbon fibre rear stone guards. Drop me a PM.
U2u'd..... But looks like i might have been beaten to it.....
Hello, I'm after a steering column with a bit more length, could you tell me how long it is from end to the boss face?
Would you be ok to post?
Thanks, Henry.
Thanks, Henry.
U2u sent re: brakes and digidash. Thanks
u2u on various bits
how much would you be after for the whole lot?
pm regarding Axle.
jeff i work near gatwick so if you want me to pick up the axle i can save you a drive
dibs on the midilites
U2U re plenum.
U2U Regarding seats. 4th Dibs if suitable and still available.
[Edited on 14/3/13 by Atlas]
Also will take a set of the tyres. Will discuss on the U2U re the other bits.
Hi
Could do with a spare set of wheels 13" et 35 ??
we are near Charlwood.
René 07831422159
Originally posted by renetom
Hi
René 07831422159
All replied i think....
Please phone me as loosing track already lol
no reply.............
sorry dude is now lol
have you got a picture of the header tank please?
No reply
Originally posted by acafrao
No reply![]()
U2U sent
Replied, brakes prov sold
Originally posted by laptoprob
U2U re plenum.
U2U re plenum.
Money sent a couplle of days ago, can you confirm you got it please?
Engine, alternator, roller barrel, oil tank, fuel rail, rack, column, fire system all sold
Adjustable engine steady £15
What size tyres went under the cycle wings?
I have 195/50/15's.
Still awaiting a picture of the header tank ?????
I have 195/50/15's.
Sorry about this being off topic but....what did you use to paint your cam cover. I cant find a suitable orange anywhere?
Is the Pedal box still available?
Iain
Iain
Sorry to see this buddy!
Dont get on here as much these days so only just caught the news!
Dont get on here as much these days so only just caught the news!![]()
Hi Goaty,
Im going to hold out for a Tilton Pedal box.
No prob mate
Hi mate ,
Do you still have the wildwood calipers?
No sorry
Only have left;
Obp pedal box
Carbon heat shield
Fuel pump and filter
Rad/intercooler
Couple of other odd and sods
