Due to a shortage of space in the engine bay I am on the hunt for an injection fuel pressure regulator which has inline inlet and outlet ports.
Almost all the ones I can find have the inlet and outlet at 90deg which is going to cause me problems
Thanks,
Regulator can be at the back of the car, many recent cars have the pump, filter and regulator in the fuel tank.
Demon tweeks sell them pro flow regulator
My swirl pot is fed from a low pressure pump at the rear and the swirl pot is under the bonnet, along with the high pressure pump and associated
gubbins.
I also have to run a MAP line to the fuel pressure reg so it would be easier if that was under the bonnet
look up eds motorsport on ebay, or his own site
i got this one
http://www.edsmotorsport.co.uk/pro-flow-regulator-65-p.asp
i got this one
If you are tight for space Fuelab 545 Series Mini Fuel Pressure Regulator's have an in-line return port or the 525 Full size also feature the
in-line return.
I've used quite a lot of Fuelab FPR's and I don't use any other in-line filters than Fuelab. They are top quality.
http://www.fuelab.com/index.php?option=com_virtuemart&page=shop.browse&category_id=2&Itemid=3
[Edited on 24/2/10 by atomic]
