Custom windscreen frame
peter bland - 1/11/16 at 01:34 PM
I'm after a windscreen to fit my Westfield wide body which has a full cage fitted. The factory screen is too short as I want it to reach the cage .Looking for some one who can make a custom screen frame . Any info welcome .
[Edited on 1/11/16 by peter bland]
Smokey mow - 1/11/16 at 02:55 PM
Have you looked at the Westfield Sport Turbo screen? They're the same width and fit in exactly the same way as the standard screen but are a couple of inches taller than standard.
mark chandler - 1/11/16 at 06:43 PM
Usual approach is to cut a plywood template, take this to your local glazing firm and get the to cut from laminated stock, last one I had made years ago for a landrover was £25.
peter bland - 1/11/16 at 07:57 PM
Will give westfield a call but expect it will be pricey.
peter bland - 1/11/16 at 08:02 PM
It's the windscreen frame I'm looking for, the glass is can get local.
907 - 1/11/16 at 11:10 PM
I obtained the aluminium sections and rubbers from Robin Hood / GBS and bent it to shape myself.
Paul G
Schrodinger - 2/11/16 at 09:13 AM
I don't know if the Tiger surround will fit but they do make them tall to be cut down.
