barbarianbeast
posted on 26/3/09 at 06:27 PM |
MK Indy R Radiator
as above, How??
i haven't got the slightest clue as to how this should go on. Its the one that MK supplied, i think its a modified escort one.
how do i mount it without fouling the inboard suspension or the nose cone? how far out/up/down should it be.
any advice or even a link to a build diary appreciated.
lococost
posted on 26/3/09 at 07:19 PM |
you can find a link to my build on the www button below. There are some pics of the rad in there somewhere. I did use the original bike radiator
(and oil cooler below it) though.
raptor700
posted on 26/3/09 at 07:46 PM |
i have just fitted mine to an indy r, it is a modified escort and if you have a bike engine they will have modified the outlets.
They supply two brakets that are about half inch bar, it is bent and looks roughly like a g clamp you then paint it and fit your rad. You need to get
the top hose above the head gasket, i have just been down yesterday they are doing an ally header tank for 50 quid it looks good and the right size
for the pipework i also bought a pipe that is bent to shape that takes fluid from the far end of the engine to the bottom of the rad as its quite a
long way. if you havent got the clamps i would buy them, i had to scratch my head a few times, if you want me to put a pic on let me know
nik
barbarianbeast
posted on 26/3/09 at 08:15 PM |
lococost, i am impressed with your build. and the way the way you have made the clutch linkage i might have to borrow that. thank you
raptor 700, i think its time i spoke to MK. i have bought the rad brackets but they must be wrong. (or off the older car, they are L shaped) could you
send that pic please.
that expansion tank sounds good do they have those in stock.
raptor700
posted on 26/3/09 at 08:32 PM |
if you imagine a g clamp with the g part at the top when the suspension moves up and down it doesn catch the bracket, if you get them and still need
the pics let me know, i wasn too shore and put a thread on myself, but the top of the radiator sits flush with the top of the bracket saves you
messing as i had the nose cone on and off!!!!
i actually saw it on the side and asked, they are making them up tho so give em a buzz, i have been looking for one on ratsport but the fittings aren
the right sizes with it been a bike. it looks a good one!!
PAUL FISHER
posted on 26/3/09 at 08:56 PM |
This is how I mounted my MK supplied radiator,on my old Indy R.![](http://locostbuilders.co.uk/upload/a914799-latest spec-r 004 (Small).jpg)
barbarianbeast
posted on 26/3/09 at 09:44 PM |
thanks for the picture, it seems straight forward now.
have you drilled straight through that chassis member and used a stantard bolt?
PAUL FISHER
posted on 26/3/09 at 10:44 PM |
Just used rivnuts in the front chassis rail.
paulmw
posted on 27/3/09 at 02:15 PM |
Mine with a bike rad. Just a couple of simple brackest top and bottom
![](/galpreviews/a915220-PICT1812.JPG) ![Rescued attachment PICT1812.JPG](/gallery/a915220-PICT1812.JPG) Rescued attachment PICT1812.JPG
