thebull
posted on 30/7/09 at 01:27 PM |
boot cover
can anyone tell me the best place to buy abs plastic or the best stuff to make a boot cover from.
thanks
graham
smart51
posted on 30/7/09 at 01:35 PM |
Mine was made from carbon effect ABS supplied by MNR. CBS and Europa sell it the last time I looked.
I found that the edges of mine gradually curled up over time. Something more rigid would be better for a boot lid.
whitestu
posted on 30/7/09 at 01:48 PM |
I made mine from ply wood covered with vinyl. It's cheap and easy to work with, and so far fairly robust.
Stu
Flamez
posted on 30/7/09 at 01:55 PM |
got mine from here , they even cut to size. unfortunately the postage
cost more than the plastic.
3mm abs used for firewall, tunnel top and boot cover.
my build mac1motorsports
Slater
posted on 30/7/09 at 02:00 PM |
My boot cover is 6mm ABS, but I find it expands and warps alot in the sun. So I will be converting over to plywood very soon.
pewe
posted on 30/7/09 at 02:03 PM |
Thin marine or exterior ply covered with thin ali. glued in place did it for me.
Looks passable espec. if you use edge trim around the perimeter, is fairly weather-proof and screws onto the outer tubing.
Only tricky bits were trying to shape it around the roll-over bar so ended up making card patterns first then four pieces which fit together using
tongues and brackets on the under-side.
Also made a hatch with Moss Plastics surface hinges and secured with Dzus fasteners so I can put helmet, her shopping etc. in the boot.
HTH.
Cheers, Pewe
thebull
posted on 30/7/09 at 03:14 PM |
thanks for your replies chaps
jase380
posted on 30/7/09 at 03:32 PM |
6mm mdf covered in vinyl on mine, no probs so far !
Richard Quinn
posted on 30/7/09 at 03:59 PM |
Now there's a contradiction
