New Topic New Reply
Author: Subject: Handbrake-cable
dutchsuperseven
Builder
Posts 105
Registered 28/2/03
Location Born, Holland
Member Is Offline
Photo Archive Go!
Building: Locost-clone, powered by zetec 1.8, sierra type N9
posted on 22/3/04 at 10:01 AM Reply With Quote
Handbrake-cable
I'm using MK-indy rear uprights on my Locost with sierra calipers.
Which handbrake-cable do i need or what is the part that MK uses?
Greetings Rob
Sex, drugs and Supersevens
theconrodkid
posted on 22/3/04 at 11:07 AM Reply With Quote
use a seirra cable and shorten it,there are various methods here to join the 2 ends again
who cares who wins
pass the pork pies
Staple balls
posted on 22/3/04 at 12:52 PM Reply With Quote
bit of brake pipe, solder, blowtorch and thick gloves
Berwyn
posted on 22/3/04 at 04:19 PM Reply With Quote
MK sell them at 22.99, but you will probably have to shorten it. I cut one end off and fitted a new nipple (solder on) but many cut in the middle and pass both ends through a brass ferrel, bit like a cable block connector (30amp size).
the choice is yours !
24 hours in a day, 24 beers in a case. Coincidence? I think not
Staple balls
posted on 22/3/04 at 05:38 PM Reply With Quote
hmmm, i wouldn't be so keen on using a cable block connector in the middle, although it might work nicely on the end to get it set right (then soldering for security)
alister667
posted on 22/3/04 at 06:46 PM Reply With Quote
I shortened the cable and re-soldered on a new nipple like Berwyn.
http://members.lycos.co.uk/alister667/
mad-butcher
posted on 22/3/04 at 09:06 PM Reply With Quote
MK cut one end off and use a solderless version of the original end .. see handbrake cable end photo in my archive.. I beleive the AA use them if your hand brake cable snaps they just thread a new length of inner through the original outer and put these ends on MK also sell them but I can't find a source.
Tony
posted on 30/3/04 at 11:58 PM Reply With Quote
We did what madbutcher has done... I believe we have pictures on the site... somewhere! If not I'll get some!!
That's the puppy!!!
New Topic New Reply
