M$RK_VXRD
posted on 18/3/11 at 12:41 PM |
Zetec to type 9 starter motor
As above I need a Zetec to type 9 starter motor
Iwas going to use the pinto starter with a 14mm spacer but the back of the starter fouls one of the engine mount holes on the sump.
By the way it's a 1.8 black top using 1.8 flywheel
posted on 18/3/11 at 02:35 PM |
2L DOHC is the one you need.
r1_pete
posted on 18/3/11 at 05:38 PM |
Take a look in my archive for pics of both blacktop and silvertop sumps modded for rwd starters.
If you want a new motor, QX Components QS1221 is about the slimmest motor you'll find.
M$RK_VXRD
posted on 18/3/11 at 07:58 PM |
Pete am I right in thinking that its a pinto starter on the black top in your pics?
