Major Stare
posted on 16/6/11 at 07:01 AM |
Bike cutout/level sensor
Relocated the R1's engine managment module and 3 other modules, one of which is the engine cut devise sensor.
When pulling the plug off to disconnect, the inside of the engine cut sensor came out with the plug. Its a PCB and a half moon disk.
Which way does the disk need to be when put back in the module?
Jon "FISH"
Davey D
posted on 16/6/11 at 09:07 AM |
It is recommended to glue the little pedulum in place when fitting it to a car, so as not to have the sensor move, and cut the engine mid corner, as
the g forces are different with a bike due to it leaning over when cornering where a car doesnt
Davegtst
posted on 16/6/11 at 09:11 AM |
Don't know about the R1 but on the hayabusa i have fitted a resistor and got rid of the tip over sensor altogether.
Strontium Dog
posted on 16/6/11 at 09:48 AM |
That's the best thing to do IMHO! The last thing you want is the engine cutting half way around a bend!
Major Stare
posted on 16/6/11 at 08:53 PM |
So, if i glue it, at which/what angle should the half moon pendulum?
Jon "FISH"
dave107
posted on 17/6/11 at 09:50 PM |
Small magnet on the pendulum should be above magnet on circuit board, just done mine R1 2003 checked the position by moving it around until engine
fired up.
