loony
posted on 4/4/12 at 09:08 PM |
Electric reverse starter motor power/efficiency
As my Haynes Roadster transmission tunnel will be wider than MK, so I decided to use bigger reverse gear (72teeth, 156mm OD).
![](/galpreviews/laser cut reverse gear sideB.jpg) ![Reverse Gear Side B](/gallery/laser cut reverse gear sideB.jpg) Reverse Gear Side B
And now - what starter motor should I use for it.
I know that VW starter motors are OK. Lots of you using VW Golf starter motor (gasoline or diesel). How efficient are they ?
I'm asking because I was thinking of VW Polo 1.2 starter motor - 0,9-1,1kW but smaller and easier to fit. (VW POLO STARTER
MOTOR FROM 2001 ONWARDS | eBay )
Would it be enough with bigger reverse gear ?
I plan not to stick anything under the floor... because of speed bumps and polish roads So the size matters...
Lucas
posted on 5/4/12 at 11:43 AM |
Diesel starter motors usually have more torque than petrol.
loony
posted on 5/4/12 at 12:31 PM |
But is there need for such "powerful" starter motor ?
1.9TDI and gasoline 1.8 has about 2,0kW
1.2/1.4 gasoline has 0,9-1,1kW
Smaller starer motors are easier to fit and need smaller battery (less weight).
Lucas
renetom
posted on 7/4/12 at 09:32 AM |
motor
Hi
we were going to fit an electric reverse but changed our mind & fitted a rev box.
I have this starter motor from an X type jag which by design seems easy to fit.
See pict on my photo archive
Good luck
René
fimi7
posted on 7/4/12 at 11:41 AM |
Keep in mind bikes do to generate that much electrical juice, so don't go wild. Meaning, don't try to build the reverse to take you up
hill too far, but rather for a simple turn around.
--- Ali
