sprouts-car
posted on 31/5/13 at 09:44 PM |
Gasket Materials
Evening folks,
Last week I re attached my intake manifold. Making a new gasket as the old one broke/ripped/snapped.
Now I thought the material I used was gasket stuff but it turns out its the worlds best absorber and transporter of water.
And as the water flows though one of the holes, this is a problem.
Now I could just order one new off ebay, ~£10 and 2 weeks wait or I could have another go with a different material.
So really I have 2 questions, what is a good material, where can I get some locally on a saturday?
I had another idea, would aluminium sheet work? I have plenty of ~0.8mm sheet left over.
Or would I never be able to clamp it down enough to seal?
Thought and suggestions welcome...
C
Build blog
posted on 31/5/13 at 10:14 PM |
Normally ordinary thick cartridge paper works fine for gaskets that run up to boiling water temperature.
Could the manifold nuts be coil bound on the studs ?.
mark chandler
A decent motor factor should be able to sell you proper gasket paper
sprouts-car
posted on 1/6/13 at 08:14 AM |
Good point, ill make sure the studs are actually doing there job.
Any thoughts on aluminum?
Build blog
Slimy38
posted on 1/6/13 at 08:37 AM |
Gasket material needs to deform in order to seal, which means the parts either side need to be a stronger material and the clamping forces need to be
sufficient to crush the gasket at least a little bit. I don't know what you're using for a manifold, i would be surprised if it met both
requirements.
I've only really experienced metal head gaskets, consider how tightly they're fitted. Are you angle tightening your manifold nuts for
example?
[Edited on 1/6/13 by Slimy38]
sprouts-car
posted on 1/6/13 at 06:06 PM |
Angle tightening solved it!! Thanks
Build blog
Slimy38
posted on 1/6/13 at 06:44 PM |
Erm, i used angle tightening as an example to apply sufficient clamping force, not sure it would have been appropriate for an inlet manifold. Sorry.
sprouts-car
posted on 2/6/13 at 05:09 PM |
No need to apologise, the nuts and studs were indeed not allowing the correct clamping force for the torque. Some cleaning and proper tightening was
the key. Thanks!
Build blog
