Author: Subject: garage clear out
iceman26
posted on 28/12/13 at 04:53 PM Reply With Quote
garage clear out
hi I have lots of stuff I need to clear out of the garage im not sure what they
are worth but open to offers on them I need them moved on
1. floor standing press its 15 ton it will need some new pins for the shelf
and has slight surface corrosion on it and the gauge not working correctly.
£75
2. bench drill 500w 9 speed chuck size 1.5-16mm I cant find the chuck key
at the moment but will look again its in the garage slight surface corrosion
but fully working.
£20
3. bench grinder 150w one of the guards has broken off but still full working
£5
4. Clarke 6 drill vice not used
£5
5. blue point auto darkening welding helmet not used but not tested
£15
6. wheels set of 4 wolfrace new with tyres have a few storage marks but nothing bad
are 6.5x15 I think pcd is 114 tyre size is 195/55/15v tyres are new
£60
7. box of roll pins only use a few
£5
8. box of o rings only few used
£5
9. selection of metal and plastic p clips
£5
I cant seem to upload pictures will put them in my photo archive
thanks
[Edited on 28/12/13 by iceman26]
CRAIGR
Contributor
Posts 2760
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 28/12/13 at 04:59 PM Reply With Quote
U2u'd re welding helmet
O rings too please
[Edited on 28/12/13 by CRAIGR]
iceman26
posted on 28/12/13 at 05:02 PM Reply With Quote
will do a picture of the helmet for you
femster87
posted on 28/12/13 at 05:03 PM Reply With Quote
Can you post pillar drill please.
I will also like the bench grinder and welding helmet if Craig does not.
[Edited on 28/12/13 by femster87]
slingshot2000
posted on 28/12/13 at 05:12 PM Reply With Quote
u2u re; press.
CRAIGR
Contributor
Posts 2760
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 28/12/13 at 05:34 PM Reply With Quote
Deffo up for the helmet and o rings
tilly819
posted on 28/12/13 at 06:04 PM Reply With Quote
Dibbs on the drill vice
Tilly
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
JohnH
posted on 28/12/13 at 06:25 PM Reply With Quote
Wheels
U2U sent about the wheels.
iceman26
posted on 29/12/13 at 01:09 PM Reply With Quote
welding helmet and o rings sold
iceman26
posted on 5/1/14 at 04:58 PM Reply With Quote
drill vice sold
