Author: Subject: GRP seats for a Striker?
CraigJ
posted on 2/11/15 at 09:03 AM Reply With Quote
I'm looking at ordering seats this week for the build and was wondering what the fit is like for the seats from kitcardirect? I have only seen there seats and 2 others who do seats for the striker (tillett and JK). Are there any other options?
z2000
posted on 2/11/15 at 10:34 AM Reply With Quote
I have a pair of the JK seats in my car and they're very comfortable and also very rigid.
I have a bad back and they feel like they support me quite well.
Just watch out on how you're mounting whichever you go for as some of the cheap ones I have found to be quite flexible.
If it isn't broken; take it apart and fix it! Build PhotoBlog:
http://z2000.co.uk
CosKev3
posted on 2/11/15 at 10:59 AM Reply With Quote
How big/fat/wide are you?
As the fibreglass seats for strikers are a tight fit.
z2000
posted on 2/11/15 at 11:35 AM Reply With Quote
haha well that's a bit of a rude question
I'm 6'5 and 17 stone. the seats are 400mm wide and I have fitted in narrower ones that JK do but I opted for the biggest I could fit in to accommodate anyone who may sit in.
How wide is the striker space for the seats? I think the Zero I have is 440mm.
http://z2000.co.uk
loggyboy
posted on 2/11/15 at 12:09 PM Reply With Quote
striker has 37cm max width, and it tapers in as the front to rear chassis member is one unit and doesn't kink at the front of the cockpit like most kits do.
Mistral Motorsport
adithorp
posted on 2/11/15 at 12:20 PM Reply With Quote
Runs in my mind that JK (and Tillet?) do a narrow seat for thr Striker/Phoenix as their standard one and most of the others makes don't fit.
http://jpsc.org.uk/forum/
posted on 2/11/15 at 12:49 PM Reply With Quote
I may have a pair of unused JK striker seats available. Let me know if you're interested.
It's Evolution Baby!
CraigJ
posted on 2/11/15 at 03:23 PM Reply With Quote
U2U sent Scootz.
Cheers for the reply's guys.
I'm 5'11 and just under 15 stone. so will hopefully fit in them, not that I have many options really.
gaz_gaz
posted on 2/11/15 at 05:27 PM Reply With Quote
Agree with this.
I'm a tad over 12 stone and Striker seats are snug.
I'd try and have a sit in a car if anyone is local to you with GRP seats.
CosKev3
posted on 2/11/15 at 05:40 PM Reply With Quote
Jesus your a lump!!
[Edited on 2/11/15 by CosKev3]
CosKev3
posted on 2/11/15 at 05:44 PM Reply With Quote
Originally posted by CraigJ
U2U sent Scootz.
I'm 6'2, 34 inch waste and 14 stone,I had some of the smaller JK'S but not as small as the striker ones and I couldn't use them as they were too tight.
That's the reason so many strikers have the horrid bench seat set up,so people can actually fit in them!!
posted on 2/11/15 at 06:08 PM Reply With Quote
Just to confirm...
The seats have the base mounts and cut outs for 6-point harnesses.
They're with Andy at AB Performance. I'm aware that he may already have someone interested in them - I've sent him an email to confirm if it's a done-deal.
Will get back to all once I know for sure.
Toys2
posted on 2/11/15 at 06:58 PM Reply With Quote
U2U sent Scootz.
Craig, I'm a similar height and just a few pounds lighter, I had the vinyl covered squab seats in my striker, but found them uncomfortable on long drives as one of the chassis diagonals rubbed my hip bone
I'm currently refreshing my striker, I've bought some cheap second hand fibreglass seats from a Westfield, knowing that they would be too wide
I've ground off any excess material from the outside, they fit at the back, but were about 40 mm too wide at the front
To get over that, I've cut a V shaped wedge from under where one of my legs will be, they now fit, I've got to glass to joint which will then be covered camping roll padding
The upshot is though is that on the sides they are only about 4mm thick, but being smooth, they are much more comfortable than chassis members!
CraigJ
posted on 2/11/15 at 07:34 PM Reply With Quote
Waist wise I'm between 32 and 34 but hopefully down to 32 by the time IVA come around. Just going to have to get a set and try them.
CosKev3
posted on 2/11/15 at 08:05 PM Reply With Quote
http://www.jkcomposites.com/7s-page.html
Mine were N3942 I think,39cm wide.
The striker version is 35cm,so you best try to get down to a 30 inch waist!!!
bi22le
posted on 2/11/15 at 10:17 PM Reply With Quote
I have one JK comp as a drivers seat and a cheap unknown for a passenger seat.
The JK one is leagues away from the cheaper one. Im 5ft 9 and 12.5 stone. 32" waist and fit in fine. Nice and snug, would not want it wider even if I could.
The swab \ bench seats are very comfortable, I drove mine to the ring and covered 5K miles at least with them. I only swapped as I was doing more track days which really require more head and trunk support.
Please read my ring story:
BDMStriker
posted on 6/11/15 at 03:27 PM Reply With Quote
Ive a set of JK Comps fitted to my striker
if youre local to Doncaster drop me a message and you can come sit in it whilst im working on it this weekend..
Im only 5"8 but 13.5 stone and 34 waist not felt pinched in them at all,.. strikers aren't the most graceful cars to get in and out of anyways, and being a shorty i use a back pad for lumbar support to move me forward, saves having to set the seat per driver..
[Edited on 6/11/15 by BDMStriker]
gaz_gaz
posted on 7/11/15 at 06:42 PM Reply With Quote
If anyone is after a funky pair of white seats to fit a striker speak to Andy at AB..
Was picking up a couple of bits today and spotted them.
